Engine Swap Question
Old Sep 11, 2011 | 01:15 PM
Andrew1320's Avatar
Car: 1990 Pontiac Firebird
Engine: V8,350,5.7 L.
Transmission: Automatic - 700r4
Hey everyone. I just bought a 350 Chevy Small Block 5.7 Liter engine to swap into my 1990 Pontiac Firebird. The question I have is, Will this engine bolt up to my stock transmission or do I need to get a different one?? Just get back to me as soon as possible. Thank You.
Any an all feedback will be appreciated.
Old Sep 11, 2011 | 01:20 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Engine Swap Question
v8 and v6 trans have different bolt patterns on the bell. youll need a v-8 700r4.
Old Sep 11, 2011 | 11:13 PM
Andrew1320's Avatar
Are you sure. Cause all the research I've done says other wise. I just found this website like 5 minutes ago (http://www.nastyz28.com/chevy-transm...tification.php). And this is what I found - THM700-R4 - 4 Speed transmission used in GM cars and light trucks with the 2.8, 3.1, 4.3, V6, Chevrolet built 305, 350 and 454 engines from 1982 to 1992. I'm thinking it will work no problem. i could be wrong but that's what I'm beginning to believe.
Old Sep 11, 2011 | 11:21 PM
BloodBassist's Avatar
Car: 87 Iroc
Engine: 350tpi
Axle/Gears: 10 bolt, unsure of gears yet
Its the same very general tranny. Diff bell housings with diff bolt patterns.
Old Sep 12, 2011 | 12:06 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
You may just need a different bellhousing. Someone ought to know this on here for sure.
Old Sep 12, 2011 | 12:24 AM
travis401's Avatar
Car: 91 Camaro RS
the bell housing is part of the trans, not separable. 100% sure you need a 700r4 from a v8.
Old Sep 12, 2011 | 12:27 AM
travis401's Avatar
Car: 91 Camaro RS
see the difference?
Attached Thumbnails Engine Swap Question-v6bp.jpg   Engine Swap Question-chevy700front.jpg
Old Sep 12, 2011 | 02:17 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Andrew1320
THM700-R4 - 4 Speed transmission used in GM cars and light trucks with the 2.8, 3.1, 4.3, V6, 305, 350 and 454 engines from 1982 to 1992.
Not all Chevy V6's are the same.
2.8 and 3.1 are 60 degree V6's
4.3 V6 is 90 degree like a 350
Old Sep 12, 2011 | 10:47 AM
Andrew1320's Avatar
Yes okay I see now. I hope you didn't think I was trying to offend you lol. Thanks for your help though. but like "New2Chevy" said, can I just get a different bell housing??
Old Sep 12, 2011 | 01:39 PM
travis401's Avatar
Car: 91 Camaro RS
no, the bellhousing is cast into the case, its all 1 peice.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
