Engine Mount Bolt Question
Old Jan 29, 2012 | 11:09 AM
13Tango's Avatar
Car: 1991 Camaro RS
Engine: Engine bay is empty
Transmission: Dont have one
Hi there, thanks for taking the time to look. I need a little help. It's fairly straight-forward, just cant seem to find the info I need.
I am dropping a 350 back into my engine bay. I pulled the old engine mounts out to replace them, and along the way seemed to have "misplaced" them.
Does anybody happen to know what size bolts and other hardware i need? I am in need of the fasteners that hold the mounts to the frame, and the ones to hold the engine to the mounts.
Old Jan 29, 2012 | 11:36 AM
Re: Engine Mount Bolt Question
Mounts to frame = 3/8-16 x 1" + flanged nuts; mounts to block = 3/8"-16 x ¾"
All common parts store items
Old Jan 29, 2012 | 12:07 PM
13Tango's Avatar
Car: 1991 Camaro RS
Thank you very much. That should get me off the couch for the day.
Old Jan 29, 2012 | 12:09 PM
13Tango's Avatar
Car: 1991 Camaro RS
Also, would you happen to know the bolt size tof the long bolt that holds both mount together?
Old Jan 29, 2012 | 05:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Should be a 5/8" bolt but is also a special bolt. Although you could use a generic bolt, you should get the proper bolts for that.
Old Jan 29, 2012 | 08:30 PM
13Tango's Avatar
Car: 1991 Camaro RS
Thanks for that. I appreciate all the help I can get from you guys.
Old Jan 29, 2012 | 10:28 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
I know the bolt head and nut are 2 different sizes. Another of the 80's-90's General's inexplicable ideas.
Old Jan 30, 2012 | 12:33 AM
AlkyIROC's Avatar
Car: 87 IROC L98
My mistake, the bolt should be 7/16" not 5/8" All 7/16" bolts have a 5/8" head and the 7/16" nuts are 11/16"
Old Jul 26, 2024 | 06:55 PM
Highlandlad's Avatar
Car: 1982 Z28 Indy Pace Car
Engine: 88 305 HO
Transmission: TH350
Hi Guys, greetings from New Zealand 🇳🇿 . Im in the current situation of needing to replace all of my engine mounts in place. I saw Eric the car guy on YouTube using a long handled swivel head ratchet ring spanner to get up to the nuts inside the crossmember. This looks like a great option to me! Can anyone tell me what size ring spanner I need for this job please?
Old Jul 27, 2024 | 02:49 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
You don't need a ring spanner. You'll need a 15mm swivel socket, and a 1/4" drive extension with an adapter for a 3/8" drive socket & ratchet.
Put a piece of electrical tape over the nuts before inserting them into the socket. That way, they won't get dropped down into the k-member...
Old Jul 27, 2024 | 03:20 PM
Engine: 88 305 HO
Transmission: TH350
Thanks for that
I have already completed the drivers side & just about done the passengers side. I did need a skinny extension for the passengers side though.
cheers for the help
Tidan
Jun 13, 2020 12:14 AM
MikeSammy
Dec 8, 2010 06:10 PM
mystikkal_69
Jul 21, 2002 08:07 PM
427camaro
Feb 22, 2002 06:16 AM
