pulling cam problem
Old May 11, 2012 | 02:12 PM
89blackm's Avatar
pulling cam problem
im pulling the cam in my 327 and when im pulling it out i can only get it out about 4 lobes before it catches and will not come any further... wondering what it could be because ive been trying for awhile now and cant figure it out??
Old May 11, 2012 | 05:15 PM
Re: pulling cam problem
Turn the crank a little bit; a lobe is hitting a rod.
Old May 11, 2012 | 05:41 PM
89blackm's Avatar
it was actually the pin from the fuel pump that was making it stick!! thanks though
and now that its how, how do i tell what it is?? there weren markings saying what it was just some stamped on the end.... but no comp cams or name on it......
Old May 11, 2012 | 06:10 PM
Post every marking you can find on it and maybe we can tell what it used to be.
Old May 11, 2012 | 06:23 PM
89blackm's Avatar
200429-stamped on the back
1539 CWC- on shaft above gear (1539 and CWC are on opposite sides of the shaft)
D 8 is under the gear (on same side as 1539)
C 8/3 (couldnt tell if it was an 8 or 3, but that is stamped under CWC underneath the gear)
On top of the shaft it looked like B O and then on the opposite side of that is and upside down 17
hope this can help someone!!!
Old May 15, 2012 | 08:41 PM
89blackm's Avatar
anyone able to get an idea of what it could be???
Infested
May 22, 2018 11:56 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Fronzizzle
Aug 9, 2015 01:15 PM
anesthes
Aug 8, 2015 09:37 PM
