Another 350 swap
Old Jun 17, 2012 | 12:20 PM
camaroboy199290's Avatar
Car: 89 iroc
Engine: 355tpi
Transmission: jasper 700r4
Axle/Gears: 4.11 lsd
Another 350 swap
Ok so I just bought a 350 that is a o piece rear seal roller block it also has the 194 160 fi heads. I'm using the rotating assembly that came in it cause it's a zz4 crate motor. I've gotten all the parts to put it in like the computer injectors and lil stuff. Now I just need to figure out a cam to put in it that dosnt require doing anything to the computer. I don't mind upgrading springs. So if anyone has suggestions on a cam I could use either roller or flat tappet. Any suggestions r greatly appreciated and i wouldn't mind buying a used roller cam just not a flat tappet one
Old Jun 17, 2012 | 11:54 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Another 350 swap
Does it have ZZ4 heads ?
Old Jun 18, 2012 | 06:23 AM
Car: 89 iroc
Engine: 355tpi
I'm not worried about the heads I just wanna no. Cam I can use with my stock computer nd get good power
Old Jun 18, 2012 | 04:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you match parts correctly, you should be able to use the computer. Might require tuning to make it better, though.
Old Jun 18, 2012 | 11:00 PM
Car: 89 iroc
Engine: 355tpi
Well the heAds r the swirl port or something like that fi heads with the 194 valves and eventually I wouldn't mind doin the computer but it's still my dd and I want it to run good
Old Jun 18, 2012 | 11:28 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
What casting # on the heads?
Old Jun 21, 2012 | 12:00 PM
Car: 89 iroc
Engine: 355tpi
Sory took a lil while to get on here but the head numbers r 14102193
Old Jun 21, 2012 | 01:34 PM
five7kid's Avatar
350 TBI swirlport heads. Fine for a mild daily driver, not so good if you want to race.
xkingcodex
Feb 12, 2020 07:43 PM
bellez77
Sep 5, 2015 08:39 PM
theshackle
Aug 22, 2015 06:52 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
