Swapping Iroc motor in, question about ECM
Old Aug 31, 2012 | 05:36 PM
at3reg98's Avatar
I have a line on a low mileage Iroc motor. I have a two door Caprice and I'm looking to install this to replace my dead 305. My question is, how big of a deal is this to do was far as the ECM and wiring goes? Would it be too much of a hassle to bother with?
Old Aug 31, 2012 | 07:38 PM
Re: Swapping Iroc motor in, question about ECM
Put your TBI intake and all that on the IROC motor. Basically, whatever is different between the 2, take off your B body motor and put on the F body one. No other considerations should be required.
Old Aug 31, 2012 | 07:44 PM
at3reg98's Avatar
Actually I have the Q-jet on this one. I'm thinking it would be easier to just get an older non-ECM motor and swap it in.
Old Aug 31, 2012 | 08:37 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
So put your carb ,intake and dist on your new engine
The motor doesn't know or care ( within reason) how it gets fuel and spark
Old Aug 31, 2012 | 10:00 PM
Precisely.
Whatever is is different between the 2, take off your B body motor and put on the F body one. No other considerations should be required.
Is there an echo in here?
Old Sep 1, 2012 | 10:21 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
If you can get the iroc engine complete with tpi, harness, ecm etc then it wouldnt be an unreasonable amount of trouble to do the swap with the efi in tact.
Old Sep 2, 2012 | 02:38 PM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
From what I understand, IROC is a trim package. The Motor shouldn't be any different.
Old Sep 2, 2012 | 03:56 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Technically it is, but at least we know it isnt the V6 he is referring to
Frozer!!!
Jan 19, 2024 04:55 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
