440 mopar engine swap into an 88 rs
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: 440 mopar engine swap into an 88 rs
OP may have just gotten tired of having to defend his swap and listening to the bickering of what constitutes a swap. You can put a chevy engine into just about anything and its cool...but try to put something else into a chevy and lookout!
That's too bad. I'd like to see how this one turned out.
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
A swap would constitute anything other than the original. If someone has a 5.0 305 TPI and he put another 305 in, that isn't a swap and I don't think that changing from EFI to carb on the same motor should be considered as a swap. I believe the main reason someone goes to a carb setup is because they don't understand or know enough to fix EFI.. There are also people that also just like carbs. A chevy 302 or a 5.4 or 5.7 would be a swap because it is something different. Even though people have put Ford or Chrysler or even a 2JZ motor in their car and someone doesn't approve.. The owner shouldn't care as it is their car and their own design, other people will find interest in it.. I hope he does go through with this and takes alot of pictures, as I know there are other people that have expressed interest in this or even possibly even thought about it themselves.
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
I'm not here to tell people what they can or can't swap in their own cars. I will be open about what you're in for with what you're considering, however.
Really different/off-brand swaps like this tend to have one thing in common - you never see pics or vids of the finished product.
Anyone can start a project, but not evertone completes them. I an not a fan of cross breading, but I would like to see this 440 swap done and running. Thread Starter
Car: 88 Rs Camaro
Engine: 1972 440 Magnum
Transmission: A-727
Axle/Gears: Curry ford 9 inch 4.39 gears posi
Car: 88 Rs Camaro
Transmission: A-727
I personally cant wait to drive it
Car: 88 Rs Camaro
Transmission: A-727
Think outside of a box always
Car: 88 Rs Camaro
Transmission: A-727
Think outside the box always
Engine: 305 TBI
Car: 88 Rs Camaro
Transmission: A-727
Its in the works doing the transmission now
Car: 88 Rs Camaro
Transmission: A-727
Guess what it fit better than expected
Car: 88 Rs Camaro
Transmission: A-727
Car: 88 Rs Camaro
Transmission: A-727
Car: 88 Rs Camaro
Transmission: A-727
they don't need to know me until the start line
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
So you bump the thread 4 months later and still nothing? Hell of a tranny rebuild.
Car: 88 Rs Camaro
Transmission: A-727
True had to rebuild gfs Camaro but now back on mine
Car: 88 Rs Camaro
Transmission: A-727
Guess we will have to see
Car: 88 Rs Camaro
Transmission: A-727
Just like the 440 engine design
Car: 88 Rs Camaro
Transmission: A-727
Lol right well its still in the works and the best part its a fun build
Car: 88 Rs Camaro
Transmission: A-727
Its getting there I keep going back and making things stronger
Car: 88 Rs Camaro
Transmission: A-727
Because this one is all mine
Car: 88 Rs Camaro
Transmission: A-727
Its not the end its the journey
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Is it done yet? I used to run a 440 dart street racer. 67 gts 383 with a 440 swap 3.92 gears Isky cam edelbrock 3x2 intake with 3 500 cfm Holley deuces and a 727 trans with b&m rebuild kit. Mallory ignition 15 btc and 30 degrees on the dist. It would launch hard enough to pull the wheels off. So I would like to know what one would do in a third gen
Car: 55 210
Engine: 454
Transmission: Muncie
Axle/Gears: 4.56
Go for it ! These engines provide a HUGE amount of torque . Be sure the rest of the car can handle it ! Plenty of Aftermarket heads , intakes , cams , cranks etc. available as well . You can go as far as 632 " if you wish (with the appropriate crankshaft / piston combo ) .B/E- body headers will probably be a close fit and you can use a turbo 350 or 400 with a J.B. Racing Trans bell housing / adapter (complete bellhousing is bolted to the trans - takes care of starter flywheel/flexplate issues ) or stick with the tried and true 727 torqueFlite. The stock rear member in the 3rd Gens are incredibly week by Mopar standards so a Forb 9" or better yet an aluminum Dana 60 is the way to go.
Best of Luck with the swap !
B R
B R
Car: 88 Rs Camaro
Transmission: A-727
The project is well under way trans is done with a huges 2800 stall new Kevlar bands and clutches shift kit and shortblock is together waiting on a 509 purple shaft and a hemi box ignition I will post some new pics soon.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Car: 86 IROC
Engine: 5.0 TPI
Car: 55 210
Engine: 454
Axle/Gears: 4.56
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
subed, want to see this thing fire up
Car: 88 Sport Coupe
Axle/Gears: 4.56
He has not logged in in nearly four years,I am curious if he got it running and driving.
Maybe this resurrection will yield and update.
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Bummer... I wanted to see those sexy side pipes in action!
Yo! I know it's been 8 years since you've been active in the forums, but I'd like a update on this swap if possible!!! Sounds sick! I've been tempted to do the same thing and I'm just curious about how hard was it..? and if you actually finished it or not..
really nice work. What kind of 1/4 mile times?
this engine bay is larger then the f-bodys,and yes this is a 440
the engine would prolly fit ut forget about headers ,we had to custom make a set for this car
Attachment 359335
Attachment 359336
Attachment 359337
Attachment 359335
Attachment 359336
Attachment 359337
theshackle
Mar 5, 2017 06:37 PM
