Need help removing engine from transmission.
Car: 1987 Chevy Camaro Iroc Z
Transmission: Automatic (700R4)
Swapping out my 305 to a 350. I am buying the 350 from a 89 Formula. I would like remove the engine from the transmission without pulling them both out together, I just need the engine. Need some advice. Transmission is a 700r4.
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Re: Need help removing engine from transmission.
Take the transmission bolts out and torque converter bolts crossmember bolts. Done.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1989 SS
Car: 82 Z28
Transmission: T400
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
My turn!
1) Support the transmission with a piece of wood laid across the jack - this will help distribute the weight.
2) Remove the dust cover and take out the 3 bolts on the torque converter
3) Remove the engine/tranny bolts (make sure all the linkages on the carb/tbi/tpi are removed
4) Lift engine out
4) Lift engine out
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I would pull both and seperate after I got them out. Much easier to pull and install both together. Look at the bell housing bolts with the engine in the car and picture getting your extra long extension and 9/16 socket up there to take them out VS taking them out with it sitting on the ground in front of you. The torque converter bolts (3 of them) are 11/16 if memory serves. If you leave the trans in the car then there is an old trick to take a wire hanger and run through the bell housing bolt holes ( the top two) and then wire the trans up out of the way.
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Take them both out at once, saves you tons of time and effort. Junior Member
Car: 1990 Camaro RS
Engine: 5.3 LSX
Transmission: T56 Built to 1000ft-lbs tq
Axle/Gears: Not Decided Yet
Coming from a guy with a lot Mustang experience (me), pull them both together. The amount of difficulties pulling my 3.1 and shoving a 5.4 into an 01 GT, pull and replace them as a connected unit.
