mechanical fuel pump?
Old Apr 9, 2013 | 07:33 PM
bigtizzles's Avatar
Car: 89 Camaro RS (lawn ornament)
Engine: 327 sbc
Transmission: TH350
Axle/Gears: Stock for now
I'm gonna put an old 327 in my 89 RS. If I decide to go with a mechanical fuel pump, do I have to remove the electric one from the tank, or will the fuel just get sucked through it if I leave it in there? I don't want to deal with buying an adjustable regulator with a return.
Old Apr 10, 2013 | 02:47 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: mechanical fuel pump?
https://www.thirdgen.org/forums/engi...fuel-pump.html
Old Apr 10, 2013 | 10:39 AM
bigtizzles's Avatar
Engine: 327 sbc
Transmission: TH350
so what can I use as a pickup if I pull the pump out? This may be a dumb idea, but can I tap a fitting into the bottom side of the tank and fashion some sort of filter on the inside? The damn regulator with a return costs quite a bit. Does the car already have plumbing for a return, or would I have to run an additional line back under the car to the tank?
Old Apr 10, 2013 | 05:29 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
https://www.thirdgen.org/forums/carb...nk-pickup.html
Old Apr 10, 2013 | 05:32 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If the car had injection stock then it already has a return line.
Some prefer the cost and ease of installing the bypass reg on their carb swap vs the hassle of dropping the tank to remove the pump
Old Apr 10, 2013 | 07:15 PM
bigtizzles's Avatar
Engine: 327 sbc
Transmission: TH350
Ok. The car hasn't been on the road since 2006 so I don't know if the fuel pump is good or not. Does anyone know where to find a regulator with a return for a good price. How bout this one. Its preset at 7psi but is adjustable from 4 to 12 psi.
http://www.ebay.com/itm/12-803BP-Holley-Bypass-Fuel-Pressure-Regulator-Return-Carb-Style-4-5-to-9-PSI-/230903675937?pt=Race_Car_Parts&hash=item35c2ee7c21&vxp=mtr
Old Apr 10, 2013 | 07:27 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Mallory #4309 is the most popular bypass reg
https://www.thirdgen.org/forums/carb...-tbi-carb.html
You may find some Chinese made copies cheaper
Old Apr 11, 2013 | 11:31 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
ALL 3rd gens had a return line from the factory, EFI and carb.
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
justin57
Aug 20, 2015 07:05 PM
