Building a LS7/LSX for my '87 Iroc
Old May 7, 2013 | 02:57 PM
Tim87Iroc's Avatar
I just joinned this site, and I've had my '87 Iroc Z28 for a few years now(Will put pics up soon) and I haven't really done much upgrades to it, just mainly maintenance. I've been doing alot of performance work to my RAM HEMI and pretty happy where I'm at power wise with the truck and really want to get my Iroc running the best it possibly can. Summer's coming up and I'll have plenty of extra cash in my pocket and saw that I'd be able to afford to build the engine that I want, It's pretty much a full LS7/LSX build. The main questions I had that I'm almost certain the 700r4 wont be able to handle the amount of power with the engine I'm building, and same with the computer, and was unsure of what type of transmission and computer to use? I have a tuning shop that did my dynotunes for my truck that is really good and I'll have them do the same with my Iroc, I just need to know where I can get the correct computer and what type of transmission would you guys recommend I use? I know it's kind of a stupid question and I've looked around in the forums for these answers but I couldn't find the answer, Thanks!
Old May 7, 2013 | 03:13 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: Building a LS7/LSX for my '87 Iroc
Welcome, to the boards! Well lets see where to begin....First, if you are going to be swapping in a gen 3 motor, you will need a completely new wiring harness and computer to go along with it. The simple answer on the 700r4 is that it wont work, the problem with this swap is all the supporting parts. Aside from dealing with building a motor you will need to source accesories, notch or replace the kmember, get headers, upgrade fuel pump, trans and rear end and plenty of other issues.... keep looking there is plenty of info on this site about ls swaps...
Old May 7, 2013 | 03:20 PM
Tim87Iroc's Avatar
Yea It's just mainly the supporting parts that I'm having trouble finding what would be best/would work. I've researched and found many different computers/wiring harnesses but unsure as well with transmission. All I have a good idea of what I'm doing is my full engine build, It's just a matter of getting the rest of the parts that go along with it :/
Old May 7, 2013 | 03:23 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
have you read this?
https://www.thirdgen.org/forums/ltx-...third-gen.html
Old May 7, 2013 | 03:32 PM
Tim87Iroc's Avatar
I have not, I can use the same supporting parts as if Im putting in an LS1?
Old May 7, 2013 | 03:52 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
LS1 and LS7 are all part of the Gen III/IV family, so for the most part, yes. The major difference that you'll need to contend with is the differences between the harness and the ECU. The LS1 and LS7 require different controllers because of the 24 tooth vs. 58 tooth reluctor wheel, as well as differences in the harnesses due to different connector styles, different throttle body style, different cam sensor location, etc.
Old May 7, 2013 | 03:56 PM
Twin_Turbo's Avatar
and also, different exhaust port profile. The LS7 port profile does not match those of the other LS heads except the LSA & LS9 head
Old May 7, 2013 | 06:23 PM
Tim87Iroc's Avatar
Alright, thanks for the advice, I'll probably be on here plenty once I get started on the swap
Old May 7, 2013 | 06:27 PM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Suscribed
italiano67
Dec 11, 2016 09:21 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
jharrison5
Aug 19, 2015 05:53 PM
mustangman65_79
Aug 11, 2015 03:17 PM
