Basic diesel swap.
Old Jun 20, 2013 | 09:12 AM
mcrandrz's Avatar
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
Basic diesel swap.
So this is a thought while I save for a motor swap. I have a 91 camaro 3.1
I have a couple questions.
Which diesel engine would work best? I'm looking for gas mileage. But still be faster than my 3.1.
what all do I need to get for this?
Posted from Thirdgen.org App for Android
Old Jun 20, 2013 | 09:32 AM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: Basic diesel swap.
an older 6.5 would be the least amount of work because its the same as a 400 a durmax will require ALOT of fab and cutting to make work both on the motor and the car
Old Jun 23, 2013 | 02:41 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Doing the 6.5 would be a near bolt-in if you remote-mounted the turbo. See my build thread if you want every detail necessary. But you can't have a/c, and I'm not convinced a 195 horse 6.5 would feel any faster than what you started with. You would need a taller gear out back. Plus you'd make the car more nose-heavy than an all-iron 454.
Someone did this in a green 4th-gen and reported 35 MPG, IIRC. There's a video of it on YouTube or Streetfire.net
If you have a few dollars, I'd want the turbo-diesel V6 from Jaguar.
Old Jun 24, 2013 | 10:57 AM
BlwnSS's Avatar
Car: 1999 Formula Hardtop
Engine: 6.2 forged ls3 Procharged
Transmission: t56 Magnum
Axle/Gears: midwest chassis fab 9/3.50
a 12 valve cummins will be the most simple to hook up wiring wise . Duramax will be the smallest.
Old Jun 24, 2013 | 12:13 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Your looking for a better mpg so I assume your looking for a cost savings by doing the engine swap. Have you looked at diesel gas prices lately? Maybe better mpg but higher cost of the fuel too. I'd consider a 4.8 LR4 engine swap (smallest LS engine made). My truck has the 4.8 & is about 1300lbs heavier along with much worse aerodynamics yet it gets better mpg than my GTA. Put the LR4 into the lighter weight & better aerodynamics of a 3rd gen & really watch the mph go up. I'd love the put a LR4 into my GTA. Better mph & higher horsepower at the same time.
Old Jun 24, 2013 | 02:18 PM
lunati397's Avatar
duramax is not the smallest with a 3 inch cowl you will still be risking scraping the ground you would have to go dry sump just to get the ground clearance along with making a larger trans tunnel and make a whole new steering becuase the exhaust is right there you can build headers but you will kill the flow on that one cylinder just to clear
6.5 diesel will be you easiest and cheapest its practically a bolt in gm is coming out with a new small diesel thats going in the cruzes that would be a awsome swap
Old Jun 24, 2013 | 08:42 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Agreed. No idea why BlwnSS is trying to chime in when I did the 6.2 ( same externally as the 6.5 ) and lunati397 did the DuraMax. We both have build threads here, we both posted plenty of pics.
GM tested an AFM LS2 'vette prototype and got 35 MPG, so you might play with that idea.
Old Jun 25, 2013 | 08:15 AM
mcrandrz's Avatar
Car: 1991 camaro rs
where is your build thread? I tried to click your profile and find it but it wont load. I'm pretty sure i'm going with the 6.5... What does it come out of?
Old Jun 25, 2013 | 12:08 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
https://www.thirdgen.org/forums/engi...2-my-84-a.html The 6.5s are notorious for cracking blocks and heads, but 6.2s do it as well. The earliest 6.2s are the best, for tight budgets, and will run fine for a long time even when they do develop cracks. Putting a 6.5 turbo on a 6.2 is common. The '93 6.5 was the best because it was turbo with a 4L80E but had no computer control of the 6.5, however, the higher-HP versions were around '99. You can find them in full-size pickups. There was a cleaner, lower-HP version offered in some half-tons some years, but even so it won't be technically legal for your car, emissions-wise. The 6.2 first appeared in 1982, and continued through '92. The 6.5 appeared in '92, and continued through 2000. There are non-turbo 6.5s out there, and a few factory-turbo 6.2s which used an early version of the Banks sidewinder kit. The stock 6.2 injection pump is good to 200 HP and 5000 RPM, I spun my 6.2 as high as 4200 on a regular basis, it really isn't happy above 3800. Late 6.5 water pumps are a wise upgrade for early 6.2s, as is replacement of the damper. More info can be found at dieselplace.com, IIRC, or even better invest a few dollars at "the diesel page". If you like how your 6.5 thirdgen creation drives on the open highway, consider swapping a new pair of Moog 5664s, adapting some 18x10.5s wrapped in 295/35s, and it might regain being fun in the twisties.
Old Jun 25, 2013 | 02:00 PM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Wow....
$750 L98
Feb 1, 2025 02:25 PM
school boy
Oct 22, 2015 11:47 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Luigytico09
Oct 1, 2015 08:46 AM
usafirebird
Sep 29, 2015 11:58 PM
