305 to 350 swap problem!!!!!
Old Jul 24, 2013 | 12:31 AM
murphymckenna's Avatar
Car: 1986 Camaro Z28 Iroc-z
So i have a 1986 camaro Z28 IROC Z that i swapped engines in. i switched a 305 for a 350 everything went well i replaced the injectors the prom the knock sensor havent replaced the esc module yet but today was the first day we started and it started up fairly easy and idled but when i hit the gas it would die almost instantly. then it wouldn't start at all it would turn over and it was getting gas as well a spark so here are some things that we did.
1. i have an 86 corvette so i took the computer and prom and put it in my camaro.
2. it wouldnt start after i had changed the computer to the stock one and kept the prom from the corvette.
3. we tried starting it with the stock comp and prom in it and same thing just was not igniting.
4. havent changed the ESC module yet.
5. did the little test that shorts the computer and turns on the fan and the service engine light blinks a number of times to tell you whats wrong and it said that the anti theft device was on or there is a short somewhere.
So i couldnt find anything on the anti theft device for this year or something that even mentioned this car having one!
So if anyone has any ideas as to what it might be please help me!!!
Old Jul 24, 2013 | 10:51 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Exactly what error codes were you getting? '86 3rd gen f-body doesn't have anti-theft, although I don't know about an '86 Corvette.
The ESC module shouldn't keep it from starting.
How did you verify you're getting fuel and spark?
Old Jul 24, 2013 | 11:36 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 305 to 350 swap problem!!!!!
The 86 vette memcal has vats enabled, When you said its getting fuel is that checked with a fuel pressure gauge ? Have you checked for injector pulse with a noid light ?
If you have injector pulse sounds like your ignition timing is way off.
Old Jul 24, 2013 | 12:04 PM
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
Not saying you have the same issue, but check the distributor timing and that the rotor is spinning. I condemned my ECU before I found out the distributor gear was striped and had jumped time. I had fuel and spark but there was no way the engine would start with the timing so far off.
Old Jul 24, 2013 | 01:15 PM
we got the error codes that say anti theft system was active or on. The check check engine light would blink 1 then 2 three times and then show the error code of 4 and 6.
We checked for spark by taking one of the plug wires and running a wire to it and watching it spark when we touched the frame. And for fuel we checked to see if there was fuel in the fuel rails by loosening a bolt. dont have a noid light but all i can say is that we had it started and it idled but nothing after i changed the computer just incase something is off about this car how do i reset the error message? or if anyone has any other ideas and as for timing we didnt loosen it enough to jump that far foward but ill check.
Old Jul 24, 2013 | 01:17 PM
also could me changing the computer from a corvette to a camaro have something to do with it?
Old Jul 24, 2013 | 02:06 PM
Engine: Lb9
Transmission: M20
Code 46 is for vats , It cuts your injector pulse when the ecm does not receive the 30hz signal from the pass key module.
Old Jul 24, 2013 | 02:10 PM
This year camaro 86 doesnt have an anti theft system so this is where im lost could it still be on this car even though its not specified?
Old Jul 24, 2013 | 02:14 PM
also we checked the voltage in the fuel injectors and with the key on we have 8 volts and with the key turned to start its at 12 volts
Old Jul 24, 2013 | 02:17 PM
Engine: Lb9
Transmission: M20
The corvette memcal has it enabled so that would throw a 46 malf, The car would start with the 305 memcal. Use a noid light the ecm controls the grounding for injector pulse when it receives DRP from the purple and white wire of the icm.
Old Jul 24, 2013 | 03:21 PM
So instead of a noid light i used a stethoscope to listen for the injectors and i heard nothing not a buzz anything so not sure if thats a fact but just incase if i had that problem where would i start to look i looked at the fuses there all fine is there a relay or a fuse somewhere i cant find?
Old Jul 24, 2013 | 03:41 PM
Engine: Lb9
Transmission: M20
Assume you are using the non vats 305 memcal, if the ecm is receiving DRP and the ecm/ injector ground is good behind the passenger cylinder head the injectors will pulse above 400 rpm. If you have a shorted injector they will shut down the injector driver anything below 12-12.5 ohms. Good coils will be 16-16.5 ohms.
Old Jul 25, 2013 | 12:26 AM
So we plugged in the noid light and we didtn get a flash or anything so im guessing there might be bad ground any ideas?
Old Jul 25, 2013 | 12:27 AM
and tested the ohms and all of them 16 perfect
Old Jul 25, 2013 | 12:34 AM
Engine: Lb9
Transmission: M20
Tring to start it now you are using the 305 86 memcal ? the purple/white wire from the ignition control module is your 5v reference square wave tach signal to pin B5 of your ecm.
memcals are identified with there 3 to 4 letters on the top called a broadcast code.
Old Jul 25, 2013 | 01:35 AM
its the stock memcal so its a 305 memcal
Old Jul 25, 2013 | 01:39 AM
sorry i dont have the memcal in front of me at the moment
Old Jul 25, 2013 | 02:00 AM
Engine: Lb9
Transmission: M20
Since the 86 f-body doesn't have vats, you might try that memcal in your vette ecm . Im Sure you have already tried that out. the ecm is powered up since you can enter field service mode. Now its down to bad ground or bad icm or a open or short on the purple and white wire from the icm to the ecm. The injector ground is pin D3 of your ecm blk/white.
Even if the memcal was faulty it would still pulse the injectors in limp home mode.
You can allways rob the icm from the vette if you are still using the hei coil in cap.
Old Jul 25, 2013 | 02:12 PM
how would you go about testing the injector ground as was anything else that needs to be tested?
Old Jul 25, 2013 | 07:26 PM
Engine: Lb9
Transmission: M20
Continuity to ground
theshackle
Mar 5, 2017 06:37 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
