2.8 to 350 cant find a thread on this
Old Aug 30, 2013 | 09:46 PM
dodgeram106's Avatar
Looking to buy an 86 Camaro with a 2.8 v-6 Automatic and want to swap to a v-8 will the transmission thats in the car bolt up to the v8.....I know the mounts have to be changed on the frame and moved forward for the motor ..........Thank's.....and if this has already been answered some where on here sorry.....couldn't find it....Thank's again............Tim.........
Old Aug 31, 2013 | 05:54 AM
OdieTurbo's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 3.4L V6
Transmission: T5 (NWC)
Axle/Gears: 3.42 Stock axle
Re: 2.8 to 350 cant find a thread on this
You didn't look too hard, the sticky is right above the normal posts...
v6-v8-swap-read
Best advice? Buy a V8 to start with. LOTS of them still out there.
Old Sep 1, 2013 | 12:07 AM
It didnt say anything about a V-8 bolting to the 2.8 transmission....Only what you need to change...........fuel lines,brake lines.....torqe arm...mounts I knew that....just making sure the 2.8 transmission will bolt to the 350 motor.. The car Im buying is in near perfect shape for 500 bucks...really clean in and out.nice paint and centerline champ 500 wheels that are hard to find..The 2.8 v-6 is junk...even when it was new..and he said it had problems anyways..There is alot of V-8 cars but most of them have been beat to death..
Old Sep 1, 2013 | 09:42 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
No the trans wont fit, the bellhousings are different between V6 and V8. It has been covered a lot, just gotta do some digging.
Old Sep 1, 2013 | 10:17 AM
OdieTurbo's Avatar
Engine: 3.4L V6
Actually it says so in item #1 on that post: Anything the V6 bolts to, and anything that bolts to the V6, will be different than the V8.
Old Sep 2, 2013 | 02:41 PM
Ok,,,,,Thanks for the help.......I think Ill just leave it there I didn't want to change out every thing on it.....I was thinking just a motor swap would be it and a few small things....Thank's again for all the help......Tim.
Old Sep 2, 2013 | 11:11 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
i did an injected V6 to carbureted 305 swap in my Camaro... the hardest part of the whole swap was dropping the tank to remove the in tank fuel pump... i used a Caprice 700r4 with the tailshaft from the Camaro bolted to it, bought some motor mounts from NAPA and used a set of engine side clamshells from Dog knows what car i tore apart up to 20 years ago to get the engine bolted in... used the stock fuel lines to feed a stock replacement 86 Camaro 305 fuel pump, bought a set of Hedman long tube Hedders, used the engine front accessories that i got with the vortec heads i used, and got a new radiator and hoses from NAPA...
the actual swap was done in probably 20 hours total, with a good chunk of that being spent fighting that stupid gas tank out and back into the car...
Old Sep 4, 2013 | 07:25 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
I hear you on that.
Old Sep 4, 2013 | 02:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A common misconception. For whatever reason, the factory used the same designation for the V6 and V8 transmissions, even though they are different. Things get "modular" at the chassis level, and some of the harness plugs (firewall, for instance), but the engines required a completely different support staff.
One of the more popular V6 to V6 swaps is the 3.4. The V6 forum has details about that. You do need to switch over a couple of things from the 2.8, but it's a pretty good return for the work you have to do. The 2.8 really was a weak engine, both in power output and longevity.
Old Sep 10, 2013 | 04:46 PM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
I'm attempting theis swap right now with a 3.1 car I hope everything goes well for you
Infested
May 22, 2018 11:56 PM
Cleotiz
Jan 6, 2018 08:56 PM
E Rod
Aug 28, 2015 05:17 AM
sreZ28
Aug 14, 2015 07:48 PM
armybyrd
Aug 10, 2015 09:23 PM
