91 RS with TPI?
Old Jan 6, 2014 | 05:24 AM
Alfredo Diaz's Avatar
91 RS with TPI?
I purchased a car a few years back that I just got the desire to get on the street. Its a convertible 91 RS. When looking under the hood I noticed it has TPI. My question is how can I find out if the original L08 engine was in fact replaced with an L98? Ive noticed that the distributor is still the same one the 91 RS uses. Maybe the previous owner just got rid of the Carb and installed a TPI.
If that's the case should the distributor be swapped out as well? Both blocks use different spark plugs and wires according to the auto parts guy.
Any help would be wonderful.
Old Jan 6, 2014 | 05:28 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 91 RS with TPI?
You can pop a valve cover and read the head casting number. Use a mirror and read the block number on the back side drivers side . Lo8 ? Do you mean Lo3 ?
Injector numbers and prom id inside the ecm will also tell a story of what may be between the fender wells.
Old Jan 6, 2014 | 05:35 AM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
Re: 91 RS with TPI?
did the 91 even have a carb option?
Old Jan 6, 2014 | 05:37 AM
Engine: Lb9
Transmission: M20
Re: 91 RS with TPI?
No
https://www.thirdgen.org/1991-chevy-camaro
Old Jan 6, 2014 | 03:58 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 91 RS with TPI?
If the block is correct for your year the casting # you seek will be on pass side
and either 5.0 or 5.7 will be cast in the shown location
If you have a casting # at that location then the block is not original
Old Jan 6, 2014 | 07:24 PM
Re: 91 RS with TPI?
I pulled number 14093627 from the back of the block right under the Distributor. Is this the cast number they used for 91 Rs Lo3 block?
Old Jan 6, 2014 | 08:21 PM
Engine: Lb9
Transmission: M20
Re: 91 RS with TPI?
Its a 305 no l98 here
Old Jan 7, 2014 | 12:36 AM
Re: 91 RS with TPI?
Man, I thought so. Thanks for all your help guys. One last question. Which spark plugs is best to use with this set up?
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
