5.3 with TPI???
Car: Lost count!!!! ja
5.3 with TPI???
Hello, i looking for some info on this swap.. and cant find none!!
I will like to know if i can use a ls 5.3 with the TPI system??
as far i know the accessory's should bolt to the block!!??
and the lower intake may need some trimming!!??
will like some input on this one.. if is possible????
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Re: 5.3 with TPI???
The architecture of the 5.3 (LS based engine) is completely different than the TPI built for a GEN 1 block. Nothing would match up, the intake ports on LS based engines are much taller than the gen 1 style engines, and there are plenty of other differences. TPI isn't that great anyway, the stock 5.3 intake is probably better.
Re: 5.3 with TPI???
Same reason it won't work on a big block, Frod, Xler, or whatever else.
None of the parts line up. Bolt holes don't match. Parts are the wrong size. Things are in different places. Maybe a few other minor details.
Why would you want to ruin a good motor by sticking THAT on it, anyway??
Re: 5.3 with TPI???
And I hear the TPI distributors won't fit either, lol.
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Re: 5.3 with TPI???
I know this, I was trying to make a funny. Sarcasm is soo hard to convey on the interwebz.
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
Sanjay
Aug 12, 2015 03:41 PM
