305 tbi to 350 carb
Car: 91 rs
Engine: 350 carb
Transmission: 700 r4
305 tbi to 350 carb
I swapped motors this weekend connected everything correctly I think new steering column when I turn key fuel pump doesn't turn on nor does motor even crank!!!! Please help as I am trying to do everything myself
Car: 1983 Z28
Engine: 385 Fastburn
Re: 305 tbi to 350 carb
Dumb question maybe, but did you hook the battery back up?
Also, putting your personal phone number on an internet forum that can be accessed by anyone in the world isn't the best idea.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Car: 91 rs
Engine: 350 carb
Removed so motor is in everything connected steering column in computer is still connected for fuel i turn key fuel pump doesnt come on nor does the motor crank
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Make sure you have all the fusible links hooked to the large battery post on the starter......
Car: 91 rs
Engine: 350 carb
How do i get the fuel pump in the tank to come on without using the computer i think that will solve my fuel issue
Car: 1998 Camaro Z28
Engine: 6.0L
