2.5 Fuel Injected swap to Pontiac 350? Need advice
Old Mar 20, 2014 | 02:06 PM
Thirdgendriver's Avatar
Car: 85` Camaro
Engine: 355 .3 bored, cammed
Transmission: 350 turbo trans
I just bought a 82` Firebird and it has a 2.5 fuel injected engine and a saginaw four speed. I am seeking advice on what I will need to do. Thanks
Old Mar 20, 2014 | 02:38 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 2.5 Fuel Injected swap to Pontiac 350? Need advice
Are you planning a Pontiac 350? Or a Chevy 350?
Old Mar 20, 2014 | 06:48 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
If you are talking Pontiac 350...it is a lot of work. But doable if thats what you really want to do. http://https://www.thirdgen.org/foru...-v8-swaps.html
Old Mar 21, 2014 | 02:33 PM
Car: 85` Camaro
Which would be less work, a chevy 350 or pontiac 350?
Old Mar 21, 2014 | 02:36 PM
midias's Avatar
CHEVY 350!!!!!!!!!!!
Also read this
https://www.thirdgen.org/forums/engi...swap-read.html
Old Mar 21, 2014 | 02:37 PM
Car: 85` Camaro
I read most of that thread and I didn't see one that would help exactly.
Old Mar 21, 2014 | 02:42 PM
Car: 85` Camaro
Ok, so either I get a Pontiac 350 from a 81 Trans Am from my neighbor, or go buy a Chevy 350 on Craigslist about double the cost or so.
midias's Avatar
It would help us a lot of you told us your final plans and patictlars.
Desired HP?
Carb or EFI?
Budget?
LSx or SBC?
Transmission?
The short list of things you'll need is the motor, trans, computer & harness, v8 front coil springs & sway bar, v8 radiator. Your best bet is to find a good running wrecked/rusty thirdgen with the motor & trans you want.
Old Mar 21, 2014 | 02:44 PM
midias's Avatar
What skills do you have? Can you weld? What equipment do you have? does the price difference outweigh the cost of adapters needed?
https://www.thirdgen.org/forums/engi...-v8-swaps.html
Old Mar 21, 2014 | 02:48 PM
Car: 85` Camaro
I was going to put a carbuered 350 in place of the fuel injected four cylinder. I may just keep it stock. I have a great 4 speed Saginaw transmission from the four cylinder. I have a shop I can work on it at and around 500 dollars. I was thinking about using it for some other stuff though, paint, etc.
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
st.evel07
Aug 13, 2015 06:15 PM
