305 to 355 swap is finally going to happen!
Old Aug 18, 2014 | 08:01 AM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Looks like the final pieces of the puzzle are coming together and it should be competed by next week.
What started out as a mild 350 rebuild of a L98 with 083 heads has morphed itself into a -
355 with 062 Vortec heads ported to flow 230,
hotter cam 226/234 112,
9.7 to 1 compression,
self aligning roller rockers,
1-3/4 dyno don headers,
serpentine system (smog delete),
CCC Qjet rebuilt with these specs in mind.
Edlebrock Performer RPM
So I walk into the engine shop where the work is being done and I ask the million dollar question.....
"What kind of power are we talking here?"
After some number crunching, I hear "oh about 400"
I said "at the crank"
They said "yep"
I said "Holy S&$)!!"
Old Aug 19, 2014 | 12:49 PM
jdreswick's Avatar
Car: 1986 Trans Am
Engine: 327 .030 over sbc
Transmission: wc t5
Axle/Gears: stock
Re: 305 to 355 swap is finally going to happen!
awesome!!!!!
Old Sep 16, 2014 | 10:10 PM
Chuck84TA's Avatar
Well after some failed attempts to actually swap the motor, all I need to do is undo the bellhousing bolts then this L69 is outta here...
then.......
Old Sep 17, 2014 | 11:04 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Are you sure about that? I was under the impression the only Vortec spreadbore available was the standard Performer, not Performer RPM (there is a non-Vortec Performer RPM spreadbore available).
Old Sep 17, 2014 | 01:09 PM
Chuck84TA's Avatar
You're right... My bad it's a standard performer
Old May 31, 2015 | 10:57 PM
Chuck84TA's Avatar
More pics...
Cam profile
Old May 31, 2015 | 11:04 PM
Chuck84TA's Avatar
Air cleaner setup
Old May 31, 2015 | 11:07 PM
Chuck84TA's Avatar
Decided to pull the A/C. Going to put the chrome valve covers on too.
The CCC qjet actually runs well. Still needs a TPS adjustment after I get the timing set though. It's a rough idle but the motor doesn't die at idle //700-800 rpm
Old Jul 7, 2015 | 10:24 AM
choff's Avatar
Where did you get that air cleaner setup? And I like the swap. I'm doing the same just need to figure out what I need yet other than the engine!
Old Jul 7, 2015 | 08:27 PM
Chuck84TA's Avatar
I found it on eBay
The air cleaner came from a 1984 Z28, so I just used my original al L69 air cleaner cover instead.
I really like the way it turned out !! Especially with the chrome covers and Pontiac blue paint on the block, kind of the old school Pontiac look I was shooting for
Old Jul 7, 2015 | 08:28 PM
Chuck84TA's Avatar
I will say this.... I needed to remove the a/c compressor to fit the passenger side intake, since I am using a serpentine belt system.... Oh well... I've got t tops anyway
Old Jul 10, 2015 | 03:42 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
i have unported vortecs on the 355 in my Camaro with the same intake as you- but with an Edelbrock 1910 850cfm quadrajet- with a .488/.510 lift cam and long tube headers.. i was out playing with my trusty old G Tech meter last weekend, and it said i was going 105 in the 1/4 mile with a bad bog off the line and a 700r4 that doesn't shift consistently.
jhawkeye
May 25, 2022 06:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
