2.8 v6 to 5.0 v8 engine swap help wanted !
Car: vauxhall vectra and a 85 camaro
Engine: 5.0
hello from sunny england ! ..i need some help and i am hoping some of my american cousins can help me out ? ..i have two 1985 camaros one a 2.8 v6 the other a 5.0 v8 ( carbed) . we have changed the v6 for the v8, engine and auto tranny , harness, and ecm all from the v8 to the v6..now the problem is the engine turns but will not fire , we are using the mechanical pump off the v8 the carb is getting fuel but the engine wont start ..any ideas ?? also did any v8s have a second pump in the tank??...any help would be welcome ..jay
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 2.8 v6 to 5.0 v8 engine swap help wanted !
They should have a electric pump in the tank.
Engine: 5.0
Yes there is a relay in that needs to be powered that would have been turned on by the computer. OR you can pull the pump and replace it with a piece of pipe and let the mechanical pump do the work.
Does the car start with starting fluid?
The pump relay is near the brake booster, looks similar to the fan relay but jumping the wrong one will cause the fan to spin.
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
If you are using a mech pump DO NOT run the electric pump. The pressure is far too great for the mech pump and the carb. The mech pump will pull gas though, but you will want to remove the electric pump and install a carb pick up.
Are you getting 12v to the coil/dizzy with key on? If its getting fuel check spark.
I just finished my 2.8 to 327 V8 swap and dealt with the fuel issue.
Engine: 5.0
so i dont need the pump in the tank to be connected can i just run off the mechanical pump?.at the moment i have run a fuel line from the mechanical pump to a fuel tank and it still wont start..i will re check for a spark tonight ..the harness and ecm from the v8 has been transfered to the v6 car
Check this link it may help.
https://www.thirdgen.org/forums/carb...nk-pickup.html
Car: 1989 Camaro RS
Engine: LH6
Car: 1989 RS Camaro
Axle/Gears: 3.73 Posi
What RubberDucky said. If it is a ccc carb here is an article about the ecu and how it works. http://performanceolds307.tripod.com/id1.html
Transmission: 4L80E/4L80E
You said the carb has fuel, so this is what's important to be talking about.
notmeps
Jul 13, 2004 04:34 PM
