how to build 400hp sbc for cheap!
Old Dec 24, 2001 | 02:41 AM
442guy's Avatar
1. strong 4 bolt main short block.(ill just see how long it takes to frag my 2 bolt)
2. comp "268"cam
3.afr 180cc alum heads.
4.airgap intake and 750 cfm holley.
416 hp at 6000 rpm
435 ft lbs at 4200
if you have a 350 already this is only a $1500 investment. thats nuts.
thought id share.
throw this in your ride, go 12s, have a nice day.
Old Dec 24, 2001 | 03:02 AM
442guy's Avatar
i also forgot, this is with 9 to 1 compression,64cc combustion chamber,
and the cam is a comp "extreme energy 268"
to me this is more like a 380 horse motor, since i dont go past 5500 rpm anyway. with its peak at 6000.
later
Old Dec 24, 2001 | 11:36 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I wouldn't have gone with the 4 bolt 400 block. The webbing is very thin for the 4 bolts. A 2 bolt block is actually stronger and you can easily put a stud kit into it for added strength.
Old Dec 24, 2001 | 02:22 PM
442guy's Avatar
i was talking about a 350 4 bolt block not a 400, maybe you saw 400hp and thats what confused you?
im useing a 350 2 bolt, they say its good to about 400 horse, so well see what happens.
Old Dec 24, 2001 | 09:59 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
check this out
this is what im gettin when i do my swap
http://www.holley.com/HiOctn/ProdLin...K/300-503.html
if you go to jegs they have the kit for 1300 dalla!
seems well worth it to me
Old Dec 30, 2001 | 11:33 PM
87irocz350's Avatar
Car: 87 Iroc
Transmission: T-5 3.42's
the trick in this equation is the cam. the 268 is a smoker...best cam out there for power. the only problem is, you have to run a stall converter with that big of a cam...otherwise, all you'll be doing is roasting tires...
Old Dec 31, 2001 | 12:28 AM
89WS-6's Avatar
Sounds pretty nice...Might look into that.
Old Dec 31, 2001 | 01:21 AM
87RS402's Avatar
Woohoo, Thats the combination I'm going to be running in my new 396 big block in 3 months. I should be able to pick up a few ponies over that because if the valve sizes, and the extra 58 cubes.
Old Jan 3, 2002 | 04:06 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
How much of an effect would switching to midly ported Vortec heads instead of the AFR's have?
Old Jan 8, 2002 | 02:27 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
Well..
How i see it.
if you do what machining needs to be done, and assemble it yourself. you can have a fresh Vortec headed 9.5-10.0 355, intake, carb and distributor, Xe 268 cam, for appox 1500 bucks including buying the block.. appox 400hp at the crank, depending on the headers, and the tuning and such.
400ponies, is no need for a 4bolt main.. a solid 2 bolt will be fine.
all depends on how much you get brand new, and how much you do yourself, and how much you rebuild as to the cost.
Old Jan 9, 2002 | 11:49 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
That's funny, I read into it thinking it was a 400ci. Nice modification combo. I would definitly consider it on my next project. But, you did peak my curiosity on a 400ci. This was my only regret, I wish I had built a 400 instead. Like they say "There is no replacement for displacement," and with a SBC that's how big we can go. Don't you ever think "what if I went with that 400?"
Hotrodboba400
Dec 10, 2019 07:07 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Jorlain
Oct 8, 2015 01:57 AM
Stryker412
Sep 7, 2015 09:11 AM
masonta
Sep 1, 2015 06:40 PM
