Install engine w or w/out headers.
Old Apr 26, 2016 | 10:39 PM
BuiltZ28's Avatar
Have freshly painted engine bay dropping in sbc. Have hedman short length headers. Would like to torque headers/gaskets on w motor on stand as its nearly impossible to get a torque wrench on w motor installed. Will it be difficult dropping motor in with the shorty headers installed (tranny in place)? Will make precautions but not looking to smash up newly painted engine bay.
Kyle
Old Apr 27, 2016 | 09:14 AM
Re: Install engine w or w/out headers.
Very few headers will go into a car attached to the motor.
Best policy usually is to lay them in the chassis, drop in the motor, bolt up the headers.
No point in bothering with a torque wrench. They're HEADERS. You're gonna be re-torqueing em 2 or 3 times ANYWAY. Just tighten em as tight as you can conveniently get em with a moderate-sized wrench.
Old Apr 27, 2016 | 10:51 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
If the won't lay conveniently, you can always usually slide them in later, but this is the way I've always done it in third gens....
Old Apr 27, 2016 | 03:02 PM
BuiltZ28's Avatar
I use remflex crush gaskets they have a torque spec
Old Apr 27, 2016 | 03:58 PM
Doesn't too much matter. They're HEADERS. You're gonna be re-torqueing em 2 or 3 times ANYWAY.
Old Apr 28, 2016 | 04:18 PM
BuiltZ28's Avatar
have you ever even used these things? They're great
Old Apr 28, 2016 | 04:36 PM
You'll see. The laws of physics haven't just been re-written. And even worse, your faith in all the ad copy on the outside of packages, will be shaken. But you'll get over it and be the better for it.
I haven't used THOSE specifically; but I've used about every other kind there is. And the one thing I've learned is, header bolts ALWAYS need re-torqued. It's really more a property of HEADERS, than of GASKETS. Just like the paint that says it covers in one coat, doesn't; and the detergent that says it removes ground-in dirt, doesn't; and the aftermarket parts that say they fit, don't.
Old Apr 29, 2016 | 08:32 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've never had to lift the engine in a thirdgen to install headers. I've installed ( All shorties ! ) Edelbrock, Headman, Hooker, Dyno Dons and last week I installed this un-identified set-up into an 86 Bird:
With that said; I would not install the headers on the engine until the engine was set into place. Since the tranny will be connected already you'll need to pitch the drivetrain on a steep angle to get the tranny/engine to slide into place. If the headers get installed before the engine is lifted into place then you might have a problem with the Header flanges hitting the cross-member when you are trying to get the drivetrain to sit onto the engine mounts due to the steep angle the engine is at when you start.
IMO It's better to get the engine set first..... then leave the cherry picker close-by and try and install the headers. If you need to lift the engine so they fit - the cherry picker ready and waiting.
P.S. I've never used a Torque wrench on Header bolts. Listen to Sofa on this; don't believe everything you read & expect to re-torque your header bolts !!!
Old Apr 29, 2016 | 02:24 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
I'm with Sofa, I wouldn't torque them. You should be able to ballpark the torque you're applying to the bolt by feel anyway, if the spec is 20 ft-lbs, don't tighten them until you're about to bust a gut. I ball parked the torque rating on my flywheel & pressure plate bolts & they haven't come flying out yet...
Old Apr 29, 2016 | 07:24 PM
BuiltZ28's Avatar
This is my 3rd set of these and Ive never retorqued a set once. Never used a torque wrench either was just interested in trying this time.
Sounds like its a real pita or impossible to install the engine with the headers installed prior. Just was curious.
Old Apr 29, 2016 | 09:11 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Gotta put the headers on after the engine is in.
Remflex gaskets are bad ***! 99% of the time u don't need to retorque them in my experience
Old Apr 30, 2016 | 04:11 AM
BuiltZ28's Avatar
Laws of physics
Old May 5, 2016 | 11:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A long time ago on a project far, far away...
Wait, it's not Star Wars day anymore...
Anyway, I installed Hooker 2055s on the engine, stabbed engine & transmission together. Installed the Y-pipe after engine & trans were bolted in.
Of course, there is another way...
Old May 6, 2016 | 06:05 AM
fokeyman's Avatar
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
OK, that made me laugh. There is always more than one way to skin a knee.
Old May 11, 2016 | 06:38 AM
1982indy500's Avatar
Hello everyone I'm new here not new to the site though been using advise from this site since I can remember, I just decided to finally create a account. I have a 1982 Pace Car and just installed a stroker motor in it over the weekend and just installed hooker shorty headers yesterday and only problem I ran into was on the passenger side(which I'm sure anyone with a/c in there car has ran into same problem) my biggest problem was it wouldn't clear the starter once I dropped starter went rite in. I don't see you being able to install headers and motor at the same time unless you do it like the pic above. Here's a preview of what I have
Old May 11, 2016 | 04:54 PM
five7kid's Avatar
I'll never pull or install one from the top again.
Old Jun 27, 2016 | 12:30 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Where were you lifting the front from?
Always been scared to lift there. Radiator core support doesn't seem strong enough.
Im used to doing it from the bottom on 4th gens though.
Old Jun 29, 2016 | 10:49 AM
five7kid's Avatar
I hooked the chain around the swaybar.
Old Jun 29, 2016 | 10:27 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
SAFETY WARNING: Don't do this with the hollow 36mm bar.
Old Aug 11, 2016 | 06:14 PM
mrestrictrplate's Avatar
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
Clean b engine bay!
Old Sep 22, 2016 | 08:17 AM
rocn7roc's Avatar
Good way to do it don't install mount bolts in case you have to ;loft it a bit.I got away with out lifting but was tight,get that coolant steel pipe farther back too,it will hit.Good luck
Old Oct 9, 2017 | 01:28 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Ok
Old Oct 9, 2017 | 08:02 PM
NoEmissions84TA's Avatar
I need more info about your PS bracket. I will be removing my A/C and have SLP shorty headers. I can't stand that factory PS/AC bracket and I am looking for brackets that will mount the PS pump similar to what you have. Is that the cheap ebay bracket? And how does it fit? Is the clearance good? Thanks.
Old Oct 13, 2017 | 12:02 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
I install mine before going in and next time im installing all the acessories before going in
someone972
Aug 9, 2016 07:39 PM
89newfun
May 1, 2016 08:11 PM
Rpm92
Apr 29, 2016 10:27 PM
Mattkovitch
Apr 27, 2016 10:56 PM
hotrodaj
Apr 25, 2016 02:33 PM
