1988 RS Camero, 1969 Z28 350 engine swap
Old Sep 30, 2016 | 11:51 AM
xRuee_88's Avatar
Car: 1988 Chevy Camaro RS
Engine: 1994 L05
Axle/Gears: STOCK
I have a 1988 camero rs that had an engine swap from a Z28 350 carbed. The folks who had it before me hard wired it and ruined the harness all together pretty much, it has shorts everywhere, the tach, and dash accessories ect... don't even work. I need to know how to go about wiring the 69' 350 carbed into the 88', Im using the old automatic T5 that was in there originally. Also I have been informed that I need to buy a new TCM for a 88 T5.
Old Sep 30, 2016 | 03:25 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: 1988 RS Camero, 1969 Z28 350 engine swap
A couple things. . .
a 1969 Z28 came with a DZ302, not a 350.
Do you have an automatic or a T-5 (manual)?
Start by tracing the wires for your gauges and testing them with a multimeter (see if you can get the gauges to "jump").
Old Jun 11, 2020 | 04:54 PM
xRuee_88's Avatar
Engine: 1994 L05
Axle/Gears: STOCK
This is the ultimate late reply but thanks I just got back into the Camaro and I have a LO5 from a 95 suburban in it about to start. At this time I'm having fuel pump priming issues. Not using ecm anymore.
Old Jun 11, 2020 | 08:28 PM
BIRD91ZRAG's Avatar
That's cause the ECM controls the fuel pump. No ECM, no pump. You'll have to wire the fuel pump relay to come on with the key.
Old Jun 12, 2020 | 12:17 PM
xRuee_88's Avatar
Engine: 1994 L05
Axle/Gears: STOCK
Thanks BIRD! What is the best thing to wire the fuel pump to as far as 'key-on' is concerned?
Old Jun 12, 2020 | 12:20 PM
xRuee_88's Avatar
Engine: 1994 L05
Axle/Gears: STOCK
What color wire is it that i tap into to wire to the ignition hot as well???
Old Jun 12, 2020 | 03:16 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
What's a CamEro?
Old Jun 12, 2020 | 03:49 PM
xRuee_88's Avatar
Engine: 1994 L05
Axle/Gears: STOCK
Originally Posted by RS Chris
What's a CamEro?
Old thread, old head.
randybdis
Feb 8, 2009 07:34 AM
CodyC123
Feb 10, 2008 08:58 PM
IWannaGoFast
Oct 7, 2006 09:36 PM
birdlvr
Dec 31, 2004 11:31 AM
Eric_7810
Aug 29, 2003 06:56 AM
