Swapping my Gen 3 305 Engine with a Gen 2 461 Pontiac
Engine SwapEverything about swapping an engine into your Third Gen.....be it V6, V8, LTX/LSX, crate engine, etc. Pictures, questions, answers, and work logs.
Re: Swapping my Gen 3 305 Engine with a Gen 2 461 Pontiac
It's not a "big block", except to the extent that Pontiac motors in general are somewhat bulkier than small block Chevy ones. All Pontiac blocks are the same "big"ness. Same bore spacing, all use the same cam, all the heads bolt up to all the blocks, etc., from the mid 60s on up to their demise. (they were the same size back before that but had other differences that precluded interchange) From the 301 to the 455. Only difference is that various displacements have one of 2 different deck heights, therefore require different width intakes.
The 455 such as you have there is one of the taller deck ones. Which will cause even more fitment problems than a short deck one would, but of course, gives you more cubes.
Let us know what you end up doing about the exhaust, transmission, and accessories.
Moog 5664 would probably be the best spring choice.
Originally Posted by midias
What 4x heads did you go with? Did you have any work done to them?
Central Virginia Machine Service built the engine so I am not sure all what they did. Mentioned that the chamber is 96-100
Other number they gave me were
4.155 bore x 4.125 stroke
camshaft lift 0.236in x 0.242ex
.110 LSA
Started the Engine on the Run stand. Ran into an issue.
After about 10 minutes, boiling water started up come up out of the top void on the center of the right head. My mechanic said the first time they ran it the top hose blew off. Really disappointing as I was hoping for a uneventful run. They think that a gasket may be blown. I contacted the builder about this and he thinks it may be a cracked head. Either way, it's going to have to be pulled apart to figure out what's going on.
I had a local transmission shop build me a competition 4L60E transmission, with stall converter, computer (w/display & tuner) with the Holley RM-9070 bellhousing.
The heads are off the engine again and at the machine shop to fill in the EGR cavities.
The body/paint guy has been having personal problems that has kept my car on hold at his shop for the past 9 months. Not cool. The car is getting moved to another shop so it can get moving again.
Would anyone recommend a Procharger for this engine?
