Swapping 305 TPI for carbureted Chevy 355
Old Jan 12, 2018 | 09:37 PM
86Formula/Iroc's Avatar
Car: 1986 Firebird Formula all options
Engine: 305 tpi soon to be 383 stroker
Axle/Gears: 4/10
I am swapping my 305 TPI for a 355 and I was wondering what I do with the wiring harness because I want the engine bay as clean as possible with no access tubes and wires. Can I still use my 700r4 and just buy a manual valve body and what would I do about the shifter since I want to keep it automatic looking with the same shifter if that's possible. How would I lock up the torque converter. Would all my gauges work still like voltage, rpm and feul? Can I still use my stock fuel pump and how would I make it work for the carb? I was thinking about just wiring my fans to a switch and turning them on when I start the car. Any other information on this swap would be much apprecieted.
~Thanks
Old Jan 12, 2018 | 09:39 PM
Axle/Gears: 4/10
Re: Swapping 305 TPI for carbureted Chevy 355
Or would it be better to just put the heads and tpi on the 355 and just go like that I do realize that it will be no drag racing machine and that is what I do with it so maybe I shouldn't do that
Old Jan 12, 2018 | 09:43 PM
Axle/Gears: 4/10
Or would it be better to just put the tpi and heads off the 305 and but them on the 355. I do know that the heads are probably smaller on the 305 and that will be no good as a drag racer unless someone has done this before and can tell that the car is fine with the 305 heads. but I do use it as a drag racer so any advice will be greatly appreciated
Old Jan 13, 2018 | 08:13 AM
Jacobaxeman's Avatar
Car: 1991 Camaro RS
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
Those heads are like putting a bag over somebody's head
st.evel07
Aug 13, 2015 06:15 PM
FConn3
Sep 2, 2012 09:01 PM
themaxman
Aug 4, 2010 06:02 PM
tcassaday
Feb 22, 2010 06:07 AM
Gambit69
May 21, 2001 01:33 PM
