Having motor mount issues v6-v8 please help
Old Mar 23, 2018 | 07:35 PM
dustint209's Avatar
Need some help here guys. I bought the car with the sbc 350 already installed. Originally a 2.8.. I pulled the 350 and after rebuilding my motor I bought new z28 motor mounts and welded them (stupid, I know. Pita to bolt them up) in the factory locations using the 3 bolts in holes for alignment. I had to fight like hell to get the bolts through and the inside rubber is sitting high up in the mount. Seems like it would be in a bind. It's like that on both sides. I'm not sure about the mounts that are bolted to the motor. They may have came from a 80's model Corvette according to engine cast number. Maybe that's the problem? The upper motor mounts I've seen for sell all look the same as what I have. Just a clamshell mount. Are they all the same?? Any suggestions?
Old Apr 2, 2018 | 10:43 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Having motor mount issues v6-v8 please help
No; The clamshells are different.
IIRC; the actual mount itself should be installed the 'right' way too. I took these pics before opening up a set of mounts to install poly bushings,..... wanted to BE SURE that I install them properly ! )
Hope this helps !!!
Old Apr 2, 2018 | 07:24 PM
NoEmissions84TA's Avatar
Thanks so much for this. I had the same question.
Old Apr 2, 2018 | 11:30 PM
John in RI's Avatar
No Problem !
The clams/mounts seem like a real no-brainer,.... till things don't quite line-up properly and you've got to double back and re-check things. You wouldn't believe how may folks never realize the clamshells are side specific.
Old Apr 3, 2018 | 12:17 AM
Drew's Avatar
What I can't figure, is how come I can find one of a pair of mounts I tucked away for a rainy day, but the other mount hasn't turned up in a year of keepin an eye out for it. I already picked up a matched pair, but that one mount drives me crazy, knowing that somewhere the other mount is out there...
Old Apr 3, 2018 | 11:55 PM
John in RI's Avatar
Holy crap - That's truly funny !
I too have a mystery clamshell ! Damn sure I put away those suckers as a pair every-time because I know they are different and I like to keep things "together". Somehow,....... 1 has gone missing. Like you I've already got another pair ready for when I need a set - but it still really irks me that I can't locate that second clamshell !
Old Apr 5, 2018 | 06:53 PM
Now you guys have me wondering about mine. I have a dedicated set for my engine test stand, and the set for my TA that should be on the block. Now I'm going to have to take a look.
Are there any factory part numbers stamped on the clamshells, and what number goes on which side of the block?
Old Apr 6, 2018 | 01:03 AM
Drew's Avatar
Yes. The mounts have the part numbers stamped on them.
According to the "Good Book of Thirdgen Parts and Illustrations", Depending on the year, the left mount is either 334970 or 334971, and the right mount is 14039436.
The combination I've verified on my cars personally is the 334971 & 14039436. It's possible the 334970 is a typo. There are also the spacers between the mount and block, like seen in this image from above...
From what I've seen, the 334971 & 14039436 combo does not use the spacer.
Old Apr 6, 2018 | 04:14 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Hope this helps !!!
What "small gap" are you talking about?...
Old Apr 6, 2018 | 05:40 PM
6998poncho's Avatar
Car: 1998 Firebird Formula M6
Engine: LS6 installation finished 8-17-2011
Axle/Gears: Stock 3.42 Ratio
I think you can do away with those spacers between the bracket and the engine block. The trucks use spacers or a spacer that has an ear for a reinforcement rod to connect to the lower bell housing cover like my K1500. The engine that I installed in my truck five years ago originally came out of a '90 Cadillac and the mount brackets were both the same on that car as well as my truck. That engine did not have spacers. It seems the F-bodies require left and right mount brackets. If it really bugs you I bet you could remove the spacers on each side and the bolts going through the bracket and mount would be much easier to connect through.
Old Apr 6, 2018 | 07:39 PM
After seeing this, I began working on my mounts to convert to the ES poly inserts. Looking at the mount, there is different bolt spacing on the top and bottom sides. So the "gap" on the side with the narrower bolt spacing is SMALL er than the other end being wider. It's easier to see on the backside of the mount.
Old Apr 6, 2018 | 07:46 PM
So I checked my clamshells. I make out what looks to be 039436 and 39497 for numbers.
My 84 TA LG4 305 never had any spacer plates behind the clamshells.
Drew, please define LEFT and RIGHT regarding sides - Driver's side or Passenger?
My older clamshells (70s) are symmetrical except for the added cage on 1 of them to capture a nut. That clamshell is used on the passenger side, right in back of the block-mounted fuel pump. The captured nut makes tightening the long bolt much easier, because sometimes it's not so easy to get a wrench in there.
Old Apr 7, 2018 | 02:01 AM
Drew's Avatar
Left/Right is always relative to being seated in the driver's seat. Left-Drivers. Right-Passengers.
You can go by the gap, or by the side with one corner lopped off.
Other crazy thirdgen motor mount tips:
-The nuts inside the crossmember can easily be accessed with the A-arms and springs in place. You can go in through the spring pocket, or either A-arm bushing hole, or the round holes nearby.
-Sometimes a wobble adapter helps to get a socket on the nuts, but regardless it's pretty easy.
-You should have bolt, mount, crossmember, washer, locknut. It's easy to drop the washers inside the crossmember if you're not paying close attention. A magnet on a stick, or a coat hanger with a hook bent in the end can be used to fish the washers out of the crossmember. Anything else in the crossmember will probably come out too. So be ready for rocks, dirt, insects, Mayan fertility idols, etc to fall out and get in your eyes. If you pulled your car out of a muddy field, or a previous owner drove it like them Duke boys, you probably will want to turn the hose on high and stuff it in each of the crossmember openings until clear water runs out the drains in the middle, you know, before starting to change the mounts.
-Getting the nuts and washers back in, is kind of a pain. You can drop the nut in your socket, and hold it in place with your tool while you tighten the bolts, but the washers probably aren't going to balance on the nut while you fiddle with alignment. A drop of regular old super glue between the washer and the nuts will keep the washer in position while you get the bolt started.
Old Apr 7, 2018 | 06:58 PM
I think I will switch to these nuts to make installation easier.
Old Apr 7, 2018 | 09:59 PM
Drew's Avatar
The washers and OE lock nuts spread the load out more, and work AOK. No reason to fix what isn't broken.
Old Apr 7, 2018 | 11:48 PM
T.L.'s Avatar
Good information, Drew...
Old Apr 8, 2018 | 09:23 AM
Drew's Avatar
No problem. I never knew they were different, L v. R, until reading in an older thread and seeing John in RI's side by side pics. When I went looking for the pair I'd tucked away for a rainy day, I opened Pandora's Box of motor mount confusion. Ended up in the GM parts catalog looking up the numbers, and now they're in my notes.
Old Apr 9, 2018 | 08:20 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
You know, I've been around these cars a lot and tore several of them down... and never realized that the clamshells were specific to their sides. I guess I got lucky putting them back together. It was just a couple days ago that I grabbed some '86 mounts to see if they would work in my 2nd gen. That's when I finally noticed the difference.
68-87Chevy
Jan 19, 2020 12:23 PM
james.gould150
Mar 29, 2011 12:51 AM
jeremymsl
Feb 19, 2011 02:32 PM
dstutz
Dec 28, 2001 05:07 PM
91banditt2
May 29, 2001 08:45 PM
