ECM help
Old Sep 1, 2018 | 01:54 PM
nightsurfer's Avatar
ECM help
OK this is what i have a 84 camaro that i want to restore has a carb I also have a 92 with throttle body. Im going to compleatly rebuild the the original motor over the winter but want to put the 92 tbi motor in while I redo it. my question is will the tbi ecm plug into the wiring I have or do I have to replace all the wiring also?
Old Sep 2, 2018 | 07:44 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: ECM help
This is a refreshing idea.
Ditching factory carburetor configuration to “”upgrade” to 1992-era fuel injection.
Yes, if you want a 1992 system in your car, you will need a compatible wiring harness.
Different ECM altogether 80’s carb vs. 90’s F.I.
davidopliger
Feb 3, 2025 09:30 AM
1989formula5.7l
Aug 15, 2015 11:35 AM
Zach/90\irocZ
Aug 30, 2011 11:32 AM
he_mech_usmc
Sep 30, 2010 01:40 PM
chuck6860
Jul 23, 2002 09:36 AM
