T56 Swap Fluid Line Connection Issue
Old Oct 13, 2019 | 07:05 AM
451stroker's Avatar
I bought a T56 from a 2004 GTO and bolted it to the LS1 in my 1988 Camaro. I used the stock hydraulic throw-out bearing from the 2004 GTO T56. I bought a Gen 4 F-body fluid line to connect from the clutch master cylinder to the throw-out bearing on the transmission. It turns out that the GTO throw-out bearing has a different line connection than the F-body type and I can't hook the fluid line into the GTO transmission. The GTO transmission carries the line from the throw-out bearing to a remove location on the side of the transmission and uses a different shape quick connect fitting.
My question is, is there any way to adapt some kind of connection to the throw-out bearing without removing the transmission?
Thanks!
Jaysz28
Mar 11, 2015 07:24 PM
88FormulaKiller
Jul 18, 2011 07:48 PM
DerrenZ
Jul 14, 2011 05:18 PM
89RsPower!
Jan 7, 2010 08:04 AM
