305 tbi to 305 carb swap
Old Oct 29, 2019 | 11:06 AM
89rskrtskrt's Avatar
Hi all, i have a running 305 with a head gasket leak. My friend gave me a complete 305 long block from his old truck.
The motor was rebuilt and runs great. The motor was pulled with all accessories and components. It is a carb set up. What i need to figure out is if i pull my motor and put that in what needs to be done so carb works other then a different fuel pump and sender. Thanks all
Old Oct 30, 2019 | 12:14 AM
Firebirdwade's Avatar
Car: 1989 Pontiac Firebird
Engine: 383
Transmission: WCT5
Axle/Gears: 3.23Posi
Re: 305 tbi to 305 carb swap
You don't necessarily need a different fuel pump. You could just put a bypass style regulator on the factory fuel lines and run switched 12v to the fuel pump relay. You will need an HEI distributor or some other standalone ignition, which can be wired to the factory ignition circuit. If it is an auto you will need a kickdown linkage for the trans. There is a ton of information on the forum about this if you do a quick look in the engine section, or a google search will give you a ton of info.
Old Oct 30, 2019 | 09:32 AM
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
Why wouldn't you just repair the head gaskets ? It would be half the work and more budget friendly than trying to make something else work. Another option would be to switch over you old intake setup to the new engine.
Mpperry001
Apr 26, 2011 01:01 PM
blimko
Mar 29, 2007 01:10 PM
griff305
Feb 28, 2007 08:50 PM
meeklay812
Jun 28, 2004 05:43 PM
Camaro_hunter_d
Mar 18, 2002 11:34 PM
