Cam stuck
Car: 1988 Firebird Formula
Cam stuck
Hey guys, I have a lq4 basically completly stripped down, all thats left is the cam, crank along with the pistons. I am having a very difficult time removing the camshaft, I have some long bolts attached to it for leverage but i can only wiggle out a third of the way. Could there be an issue with the camshaft bearings?
Re: Cam stuck
Turn the crank a quarter turn or so.
Lobes can hang up on rods.
If that doesn't work, try a slide hammer, and be ready to replace the cam bearings after the one in question comes out with the cam.
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Cam stuck
I take the timing chain off, then put the cam gear back on and use it to remove the cam. Keep slowly rotating it, & rotating it, while carefully pulling it forward.
The mechanical fuelpump pushrod isnt still in there by chance?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Cam stuck
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Cam stuck
Just put the cam gear back on the cam with the 3 bolts. Finger tight is fine. No chain. Then use the cam gear to rotate the cam by hand, as you lightly pull the cam forward. It will move the lobes to different positions when you rotate the cam so you can slide them through the cam bearings more easily.
Car: 87 iroc-z
Engine: 454
Transmission: th350
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Cam stuck
I had a hard time getting the cam out of my LQ4, wound up that one cam bearing had come out of position with the cam and was getting hung up. You will probably have to pull hard and turn the cam at the same time. Maybe even set the block on end so the bearing isn't stuck on a lobe or journal while you're pulling
redneckjoe, I thought it said LG4 also, lol
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Cam stuck
This. Also, take the rear cover off and look in from the back. You should be able to see the other side of the cam and what it might be hanging on or if there is a bearing that walked out and jammed against a lobe.
Re: Cam stuck
I'm guessing a bearing will come out along with the journal it's involved with. You'll probably have to cut the bearing in half to get it off, to then get the cam the rest of the way out.
Re: Cam stuck
Yeah that's kinda what I was expecting to see... bummer, but only a minor stumbling block really.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Cam stuck
Buddy had to go through his LQ4 for the same reason. Cam bearing walked out.
I thought it said LG4, lol. I'll go stand in the corner with my dunce hat on
