Holley 302-3 LS swap oil pan
Old Sep 27, 2020 | 10:15 AM
Buckgnar's Avatar
Car: 1985 IROC clone
Engine: 383 L33
Axle/Gears: built 10 bolt
Just dropped my freshly built LS into my 85, and found when I was looking at pans to buy there wasn’t a lot of pictures out there showing how much clearance the pan actually gives you. So now that the motor is in, here you go!
Close to 2” in the front, and pretty well level with the bottom.
Ground clearance
Pan to crossmember clearance
Old Sep 27, 2020 | 10:21 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Holley 302-3 LS swap oil pan
Good to see in a car. I think all three Holley pans should work in our chassis'
Old Sep 30, 2020 | 07:19 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I should have just bit the bullet and bought a holley pan. The F-body pan works for most cases but its nice to have the flexibility to move the enigne around when you are dealing with aftermarket chassis parts like tubular K-members, trans cross members and engine mounts.
Old Oct 1, 2020 | 02:57 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Thanks for sharing the pictures. This will help people make decisions in the future
Old Oct 1, 2020 | 10:50 AM
Buckgnar's Avatar
Engine: 383 L33
Absolutely. Between this pan and the UMI motor swap plates, it made dropping this engine in easier than a SBC. Straight drop it with no clearance issues whatsoever.
Also if the steep price of this pan makes you a bit reluctant to purchase, I just found out a week or two ago that a company named “top street performance” makes a pan almost identical for significantly cheaper. Oh well. 😂
Old Oct 4, 2020 | 07:49 PM
Abubaca's Avatar
Thanks for posting. .....definitely something I've thought about
Old Nov 9, 2020 | 03:17 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
If I am not mistaken, the transmission utilizes some of the bolt holes on the lower section of the oil pan. Does this pan have those holes as well?
Old Nov 9, 2020 | 03:37 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Nope. The trans only bolts to the block. There are however some long bolts at the rear of the pan, but nothing connects the pan to the trans.
Old Nov 9, 2020 | 03:40 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Uh, my T56 and my 4L80E both bolt to their respective factory pans (as do I believe the 4L60E for the LSx cars) and the aftermarket pan in my 92 Firebird also has provisions for the transmission to bolt to the pan.
Old Nov 9, 2020 | 03:41 PM
Buckgnar's Avatar
Engine: 383 L33
Yes it does! The two bottom bolts for the bellhosing go into two holes on the oil pan.
Old Nov 9, 2020 | 03:42 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
looking at the Holley website, it looks like it has provisions for the transmission attachment points
https://www.holley.com/products/oil_...ns/parts/302-3
Old Nov 9, 2020 | 03:43 PM
Buckgnar's Avatar
Engine: 383 L33
You can see the two bottom bolts in this picture
Old Nov 9, 2020 | 03:44 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yup, I stand corrected. Just climbed under my car to verify as well.
SteelDirigible
Mar 22, 2020 08:18 PM
gadocbar
Mar 22, 2020 01:19 PM
Iroc_Lopez28
Jan 9, 2017 12:16 PM
Fireslash
LSX and LTX Parts
Mar 11, 2016 04:32 PM
mw66nova
Apr 7, 2010 12:04 PM
