I'm trying to put a 1985 l98 Corvette in a 1989 rs camaro body
Old Dec 13, 2020 | 04:44 AM
Horacio's Avatar
Engine: 2.8l v6
The camaro was my first car. My logic was take the 85 Corvette and stuff it into the Camaro. At first I thought it was just taking out the transmission and motor and all the electrical stuff and jerry rigging it to work but now I don't know if It works like that. Idk why I thought it did. I just wanna double check before I start taking everything apart, a little how to plan before I start. Any help is appreciated.
Old Dec 13, 2020 | 04:46 AM
Horacio's Avatar
Engine: 2.8l v6
Re: I'm trying to put a 1985 l98 Corvette in a 1989 rs camaro body
I'll post pictures tomorrow morning.
Old Dec 14, 2020 | 11:00 AM
GeneralDisorder's Avatar
There's not really anything special about an 85 Vette engine - should more or less bolt into the Camaro. What trans is in the Vette? I would start with a new harness and switch it to a speed density 90-92 computer though. The frequency MAF, it's special computer, and the ancient wiring from 1985 would make that a solid pass in my opinion. Not even worth the effort to pull it. Almost certainly going to want some new injectors, a new fuel pressure regulator, and a new fuel pump in the Camaro. Probably a re-seal on the engine - if it were me I would be doing at least a cam and a timing set, and all new gaskets, etc. You don't want a leaky pan gasket after it's in the chassis.
GD
Old Dec 14, 2020 | 12:28 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
get a service manual for both and find where the electrical hookups are in the respective cars and hook em up, as long as you satisfy the demands of the camaro computer (the corvette has everything available for the camaro) the only other thing you need is accessories and exhaust from the camaro. trans from a camaro should stay (tailshaft housing and torque arm mount are different)
Old Dec 14, 2020 | 12:38 PM
Horacio's Avatar
Engine: 2.8l v6
my donor car and my RS pride and joy XD
Old Dec 14, 2020 | 01:22 PM
427seven's Avatar
what kinda rear end is in that vette?
Old Dec 14, 2020 | 04:42 PM
Dana 36 if memory serves. Seems as though some got 44s but I could be wrong and don't know the details in any case.
Regardless, it's moot to our cars; the rear is practically part of the "frame", structurally. A whole other beast.
Old Dec 14, 2020 | 06:16 PM
427seven's Avatar
only the OD manuals got 44's except for the later LT's etc., which that is not. I just wondered if it might be a 44 and it was being parted out.....
Old Dec 17, 2020 | 11:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Later LTs got D36 if auto trans, D44 if manual trans.
The Grim Reaper
Car Audio
Aug 18, 2016 10:32 AM
gt4373
Mar 17, 2016 06:37 AM
Chevy8588
Sep 6, 2009 10:39 PM
tbonebuggs
Oct 3, 2007 02:32 PM
Black363IROCZ
Oct 25, 2003 04:30 PM
