Where is my dream engine?
Old Jan 16, 2002 | 06:13 PM
GreenProStreet's Avatar
I want to find a decent LT1 or LT4 to build up, but I am stuck. Where should I be looking and for how much?
Old Jan 16, 2002 | 06:27 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You specifically want an LT1/LT4 or do you think they make more power?
Old Jan 17, 2002 | 02:42 PM
This isn't for my SC. I want to build a motor to do a land speed attempt, and the short runner length will give the perfect horsepower. I could do a TPI 350, but buying a Miniram would almost make-up the cost of the whole engine.
I just dont know where to look! (?)
Old Jan 18, 2002 | 01:29 PM
mat89RS's Avatar
Hmmmm.... I don't know if you'd like to know that but Bill Grant is building a 2500 hp engine on a 28 pound tube chassis to do a world speed record, is car is pulling 4 g of accelaration...0-100 mph in 1 sec. !
hard to beat !
Old Jan 18, 2002 | 01:34 PM
mat89RS's Avatar
Made a mistake , Gale Bank is the name
http://www.bankspower.com/HighPerformance.cfm
Old Jan 18, 2002 | 05:51 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You're joking..... right???? I would say your aspirations have outrun your capabilities and knowledge base. You'd do best to hook up with a group doing the same thing and start learning from them.
Old Jan 21, 2002 | 07:32 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
What speed are you going to attempt?
Old Jan 22, 2002 | 03:41 PM
Forgot about this post.
I would not try to attempt to break the self-propelled mod vechicle world record. Hmmmm... Lengthen, channel, 2000 hp achohol motor. Nah, to much work. BTW, it does not matter the weight of your vechicle in a land speed car, so it seems redundant to build a tube frame chassis.
I want some thing that I can build to 700-800 hp, (or at least 600) to throw in a specially preped Firebird. Lengthy project, but I want to attain 250 mph, (but, maybe, with different gearing pull 10s in the quarter.) Could do it easily with the LS1, but the LT1 would need some finessing.
But I need a motor first! Any suggestions?
PS- I am not an idiot (re- the speed record)
Old Jan 22, 2002 | 11:22 PM
Drastius's Avatar
Car: 1985 Camaro Z28
Engine: Caprice LT1
Well i'm no expert on the subject, but I would say get yourself either engine and twin turbo it. Drop the compression ratio, some high octane fuel (maybe aviation fuel), and run like 8-10 pounds of boost. Lingenfelter is getting ~650 hp from those new corvettes with twin turbos on them, i think he's only running like 6 pounds of boost.
250 mph hmm, i would guess you would need over 800 hp to power through the air. Might want to do some aerodynamic modifications too.
Old Jan 23, 2002 | 07:30 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Heres what you want, low compression 502 with an ATI intercooled supersharger strapped on. I've seen these motors put out 1000hp.
As for 250mph, that's tough in a stock bodied car. Lingenfelter got a trans-am to 298mph but it took him 1400 hp to get it there. The sledgehammer could do 254.7mph in street trim but callaway had a body package built for that beast specifically designed for 250mph.
Not saying it's impossible, it just needs to have a lot of planning injected into it.
Rob
Old Jan 23, 2002 | 11:10 PM
EvilCartman's Avatar
Car: '82 Z28
Stock McLaren F1 does 247 mph
Old Jan 24, 2002 | 01:09 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Yeah, but the Mclaren was specifically designed for that. It was lighter than a jay cloth and had almost no rear downforce.
Old Jan 24, 2002 | 02:31 PM
Actually, jet fuel has lower octane than diesel!!! Less refined. I think that nitrous should do well for 700 hp.
Old Jan 24, 2002 | 03:23 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
weight doesnt matter for top speed.......what the hell are you talking about. What do you think causes parasitic drag. Aviation fuel is like 100 octane -You are out of your league
Old Jan 24, 2002 | 03:34 PM
Drastius's Avatar
Engine: Caprice LT1
Umm, by aviation fuel, I meant fuel used in radial engine prop driven planes. Not brayton cycle turbines (I believe they use kerosene, not sure though).
A lot of aviation fuel is well over 100 octane, and also you should not compare diesel fuel to normal fuel when it comes to octane rating.
Old Jan 25, 2002 | 01:41 PM
shiner16's Avatar
The McLaren's speedo posted 247, the R&T radar gun pegged it at 217. I read the article too. BTW, one of Lingenfelter's Vettes that was participating in the test at the same time, ran an unoffical 218 mph w/ the cats removed.
Old Jan 25, 2002 | 02:06 PM
Tas's Avatar
Tas
try the www.camaroz28.com classifieds
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
