Accesory Drive for SBC with Vortec heads
Old Oct 4, 2021 | 03:54 PM
titus1531's Avatar
Hey guys,
I am almost done rebuilding a 5.7 355 and need to find a junkyard accessory drive. I am running 906 vortec heads. Do any of you know a vehicle I can pick an accessory drive from that will work? My block casting number is 3970010. I think I can get one from a 1500, but wanted some wisdom in council. Thanks.
Old Oct 4, 2021 | 05:54 PM
vorteciroc's Avatar
Top Answer: 1
Re: Accesory Drive for SBC with Vortec heads
When you say accessory-drive, do you mean:
-The Pulleys
-The Brackets
-All of the Accessories (Alternator, PS Pump, AC Compressor, Etc)
Or do you just want Brackets and Pulleys?
Old Oct 4, 2021 | 08:17 PM
titus1531's Avatar
Either. If I can get the brackets I can buy the other components later. Although I'd be fine with getting all of the accessories with it, if that's possible. Do you have any ideas where I could do either of those options?
Old Oct 4, 2021 | 09:03 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
What vehicle is the engine going in and what induction system are you going to be using?
A TPI or other induction system that has a throttle body located about the same place as a TPI system is going to need a serpentine accessory drive system from a TPI car if using a factory system.
Old Oct 5, 2021 | 07:24 AM
titus1531's Avatar
It's going to be a carburetor. It's going in an 89 Camaro RS.
Old Oct 5, 2021 | 05:41 PM
Airwolfe's Avatar
What accessories are you going to be running?
Water Pump, Alternator, Power Steering Pump, AC Compressor, Smog Pump.
Old Oct 6, 2021 | 09:27 AM
titus1531's Avatar
Everything but the smog pump.
Old Oct 6, 2021 | 01:07 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I'm a fan of the 88-92 serp setups also used in caprice of those years or there abouts.
Old Oct 6, 2021 | 08:37 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
That is the same system that GM Performance sells. The 88-92 are the same TBI or TPI. Will work with a carb as well. Had one on my 80 Corvette. Only had to use an underdrive crank pulley on it to clear the front crossmember and it went right on.
mckenzie
May 30, 2024 08:48 AM
skinny z
Nov 13, 2015 08:17 PM
midge54
Feb 24, 2012 09:07 PM
blksc
Jan 11, 2003 08:57 AM
