85 iroc swap with 92 350 tpi
Old Apr 6, 2022 | 12:14 AM
85NightRider's Avatar
Car: 1985 IROC
Engine: 5.7
Axle/Gears: 3.45 BW 9 Bolt
Hey yall,
Putting a 350 tpi from a 92 z28 into my 85 iroc (originally 305 tpi/700r4). Can I use the engine bay/interior harness from an 87 tpi to run both the 92 engine and a 87 ecm in my car? I will be converting the SD to MAF.
Old Apr 6, 2022 | 01:55 AM
3rdgenzroc's Avatar
Car: 86 Iroc-Z
Engine: 383 HSR
Re: 85 iroc swap with 92 350 tpi
Originally Posted by 85NightRider
Hey yall,
Putting a 350 tpi from a 92 z28 into my 85 iroc (originally 305 tpi/700r4). From what ive read in the swap sticky, it's a bit different for the 85 year. For anyone who knows the swap for the 85, what exactly is needed? I know I'll need to use a 86+ ecm/harness, is that it?
You might want to read up first on the differences of Speed density (SD) and MAF to decide on which way you want to go, and it will dictate which ECM/chip you will need to use, along with the set up for your intake you will have. Also the differences on the accessory style you need for your engine (V-belt VS serpentine), which will also affect what harness you will want. There is many differences between the years on all of these.
PAJAMAZS57
Aug 13, 2017 11:16 PM
cainestl
Dec 28, 2007 07:41 PM
rudij
Jul 17, 2006 11:59 AM
ajm_shorty
May 6, 2004 06:58 PM
MTPFI-MAF
Dec 30, 2003 05:48 PM
