305 to 350 prom (i am a newbie help please)
Old Dec 28, 2003 | 04:40 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Ok I have read (intro to prom burning) I have a 1985 camaro with a 305 TPI w/MAF The car originaly had a 700r4 But Now Has A T-5 and still has the stock chip Is there any thing to change in the chip that will make a difference since there is a t-5 Now.
Also I purchased a GM goodwrench 230hp 350Long Block. I will be swapping the tpi On to this engine in about 3 months. What equipment do I need to burn chips (i don't want to data log anything yet.) also What chips do I need for a 1985, I think that in 85' the prom just pulls out. And how do I get the right .Bin file and Ecm File for a starting point for a 350 tpi w/t-5
Thanks.
ps I know that i should swap harrness to a 86'-89' because the ecms and ALDL connection and ecm are faster but just want to get it right for now. Ecm and harrness swap will be late next year.
Old Dec 28, 2003 | 04:53 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Tunercat i belielve has the software for your 85 tpi...
Everyting else u ask of is in all the stickies at the top of the page. Pay special attention to Trax's guide/intor to prom burning...lots of great info for newbies....
Read thru that and other stickies and do some searches for what u are looking for, than if u have more questions feel free to post :-)_
Later
Jeremy
Old Dec 28, 2003 | 08:05 PM
Morley's Avatar
Re: 305 to 350 prom (i am a newbie help please)
Well, you don't need to swap the harness, justthe ECM. The harness you do a little repinning and like 5 splices to work with the 165 ECM.
Tuning the 870 prom to work right with the 350 would be a waste of time if you plan on doing the 165 swap a little later because you'll be doing a re-tune of the prom in the 165 also.
You could just get the prom for the 85 Corvette and a set of 24# injectors to get you by with the 350 until you get the 165 swap done.
Old Dec 29, 2003 | 06:09 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
where can I get a prom from a 1985 corvette, Besides the junk yard , can I buy one new from a part store.
Old Dec 29, 2003 | 10:01 AM
Morley's Avatar
From GM
Old Dec 30, 2003 | 01:00 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Is it so that -85 vette uses 35 psi fuel pressure with 24 lbs injectors,and is that -85 (870)350 chip direct swap?
Old Dec 30, 2003 | 03:10 AM
Morley's Avatar
Yes, the 85 Vette used 38 PSI with 24# injectors. The chip should be a direct swap, the Vette, T/A & Camaro's all used the 870 ECM in 85 (TPI apps that is)
Old Dec 30, 2003 | 03:41 AM
z 28 jari's Avatar
Engine: 385
Morley,
do you know how "forgiven"is that -85 vette chip at modified engine?(cam ,exhaust,better heads)
Old Dec 30, 2003 | 05:48 PM
Morley's Avatar
Morley,
Being a MAF system it will be somewhat forgiving, more so than a MAP system will be. The cam would really be the kicker, depends on how much more duration and lift over the stock one you'd be going.
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
