Camshaft Question
Car: '84 TRANS AM
Engine: 5.7L SBC
Transmission: TH700R4
Axle/Gears: Stock 3.73 Posi
Camshaft Question
I'm building up a SBC for my Firebird, and I've got the pistons and crankshaft installed, so I'm about to install the cam. Do I need to install it dry, degree it in to make sure it's correct and then take it back out, oil it up and put it back in, or can I degree in the cam when it's got oil on it?
As for the oil, I've got the camshaft manufacturer's recommended oil for the job.
Re: Camshaft Question
You can degree it with the build lube on it. Especially if you're using the lifters that will stay with the build.
Car: '84 TRANS AM
Engine: 5.7L SBC
