new cam question?
Old Jun 27, 2009 | 01:47 PM
89T-top's Avatar
Car: 89 camaro rs
Engine: 3970014/block 350
Transmission: 700r4/shift kit
Axle/Gears: 2:73/going with 3:73's soon
new cam question?
What oil should I run for breaking in a new cam?
Old Jun 27, 2009 | 05:05 PM
lktna's Avatar
Re: new cam question?
If it is a roller cam you don't have to break it in. If it is a flat tappet you can run any 30 weight oil and get a bottle over break in oil from Lucas or any company like that. Or you can use any racing oil but be prepared to pay a pretty penny for it around $4.99 up a qt. A bottle of Lucas will cost around $10 or so. Here is a link to what you would need. http://www.lucasoil.com/products/dis...show&headTitle= - Engine Break-In Oil Additive - TB Zinc Plus
Also on a side note you will need to add it to every oil change to protect your flat tappet cam.
Old Jun 27, 2009 | 07:43 PM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
I alwasy use Joe Gibbs break in oil!! Todays oils do not have the zinc that u need for proper break in with a flat tappet cam. Make sure u atleast use some kinda break in additive if your going to use reg oil.
Old Jun 28, 2009 | 10:47 PM
89T-top's Avatar
Car: 89 camaro rs
Thanks I'm installing a summit 1107 flat tappet cam (.488/.510 lift), along with there valve springs lifters and double roller timing set. I also swapped out my summit stage1 intake for an eldderbrok performer rpm. I'm going to just go ahead and run a full break in oil instead of running just an additive now.
Seems to be the safe way to go. Sorry for asking such a simple question, I just don't want to end up wearing down cam lobs because I did not do a proper break in.
Old Jun 28, 2009 | 11:04 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What heads do you have?
Old Jun 29, 2009 | 12:30 AM
89T-top's Avatar
Car: 89 camaro rs
As of right now 100% Junk, 462624 76CC low comp, smog junk. I understand low compression and this cam are not the best pick but the heads are coming off soon anyway.
I'm going to be running the 210cc pro comp heads with 64cc
Chambers in a few mouths here.
Old Jun 29, 2009 | 09:19 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
The 1107 has too much lift for factory castings, you'll be hitting the bottom of the retainer into to the top of the guide bosses. About .470-.480 is the max number on stock heads.
Old Jun 29, 2009 | 02:55 PM
89T-top's Avatar
Car: 89 camaro rs
do you think I could get away with running the sum-1105 465-488 lift for now with the stock castings?
Or what cam would you recommended for now? I have $300 to get started on a cam swap.
Old Jun 30, 2009 | 12:13 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
You might be able to get away with the 1105, esp. if the intake sides have the positive style seals, and the exhaust sides do not. However, without exact measurements, I generally recommend that both sides are kept under the .480 marker.
Personally, I wouldn't bother changing cams if you're changing out cams in a short while - you'll just end up wanting to change out cams again, then. Just sit it out and when you get the new heads, get the cam that most benefits then.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
