Oil pressure sensor
Old Jun 25, 2023 | 01:28 PM
Radron's Avatar
Car: 85 iroc
Engine: 350 tpi dropped in
Oil pressure sensor
Ok got another problem. I have an 85 iroc that of course had the 305. But I am trying to put
The finishing touches on getting a 5.7 out of a newer one and I'm trying to figure out the difference in some of the wiring. Right now I see that the 85 had a single wire oil pressure sensor and the newer has a three wire connector. How do I adapt the new to the old. Thanks if you can help.
Old Jun 25, 2023 | 01:32 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Oil pressure sensor
If tpi the only is 2 wire ops and larger for gauge or idiot light. If you have a 3 wire it contains ops and control for light or gauge depending on how it’s made. You can use either one or use the stock 85 oil T and previous sender and switch.
Old Jun 25, 2023 | 01:33 PM
By putting in the right sending unit (it's NOT a [mrspock] sen-sore [/mrspock]).
Old Jun 25, 2023 | 01:35 PM
Engine: Lb9
Transmission: M20
https://www.tpiparts.net/inc/sdetail/3995
iirc center goes to gauge or light
Old Jun 25, 2023 | 01:37 PM
Radron's Avatar
Car: 85 iroc
It is a tpi and when I looked up a oil pressure sensor for an 85 it has a single connector, just an idiot light on the dash. But when I pulled out the one on the 350 it has a three prong connector. The tap is different on the two sensors. Is there a way to use the 85 type in the new motor like a reducer or something?
Old Jun 25, 2023 | 01:39 PM
Engine: Lb9
Transmission: M20
It’s npt, just goto the hardware store and get what you need
Radron's Avatar
Car: 85 iroc
yes but the 85 only has one wire going to the sensor
Old Jun 25, 2023 | 01:40 PM
Radron's Avatar
Car: 85 iroc
that's what I was wondering if it would work thx
Old Jun 25, 2023 | 04:45 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Again, it's NOT a "sen-sore". It is a SENDING UNIT for the oil pressure gauge...
Old Jun 26, 2023 | 08:15 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
You need to use the sending units for the car. Don't worry about whatever is currently on the 350 engine (except maybe the knock sensor, if you even use them)
Firebird2011
Nov 25, 2019 01:59 PM
Michail
Jan 1, 2008 08:18 PM
CamarosRUS
Jun 17, 2006 08:29 PM
mantiz85ws6
Dec 15, 2005 05:00 PM
