LS4 swap into '85 IROC -Z?
Car: 1985 IROC Z
Engine: 305TPI (LB9)
Transmission: TCI 700R4
I'm wondering if an LT4 will easily install into an '85 IROC-Z? I'm sure an oil pan swap will be required. I'm also wondering how to wire-in the ECM to the original wire harness??THX...Joe...
Last edited by scorpiusx; Dec 1, 2023 at 10:03 AM. Reason: Incorrect information posted, Typo
Car: 85 Z28/87 IROC-Z/92 B4C
Engine: Twin turbo LS9/SC LS9/L98
Transmission: RPM T56/T56 Magnum/700R4
Axle/Gears: 9"/Dana 44/10 bolt
Re: LS4 swap into '85 IROC -Z?
The LS4 is designed for front wheel drive applications. They dont have a starter pad and they use the 60* V6 transmission bolt pattern. So it makes swapping them into a RWD application nearly impossible.
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
Sure its possible to make a front wheel drive thirdgen, or are strut towers too narrow?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
This is correct. The block is also different on the back end an the intake manifold is horrible. The LS4 is only good for stealing the heads (799) and rods.
Car: 1985 IROC Z
Oops, my bad, Typo, I meant to inquire about an LT4 swap, not an LS4 swap. Jegs's THX...Joe
Part Number: 809-19431955K1
The LT4 definitely can be done. It has been done a couple times by now. I would contact Speartech for the engine harness. You will need a serious transmission to handle that power. You can run the 8L90 that comes behind the LT4 in the Corvette or the 10L90 that comes in the ZL1 camaro. They both might require some modifications to fit the tunnel though. Hawks Motorsports sells the swap headers, mounts ect.
Car: 1985 IROC Z
How hard or easy is it to wire-in the ECM into the existing OEM wire harness??? Do they make it plug-n-play or is it a DIY hack install?? THX...Joe
Car: '90 RS
Engine: 377 LSX
The engine harness will be completely unique to whatever engine you swap in. There are DIY and aftermarket solutions. Both require integration into the chassis harness of the car. Take a look at the swap forums and read the stickies at the top.
