5.0 to 5.7 engine swap.
I'm preparing to replace the 5.0 in my firebird se with a brand new GM 5.7 crate motor. The question I have is will any update need to be made to the existing ecm in the car to accommodate the new slightly larger motor? The new motor will have a Holley 4160 carb. No efi. Thanks in advance. IanB
Re: 5.0 to 5.7 engine swap.
What car? What engine is in it now? (which 305, that is... carb? TBI? TPI? what year?) What "crate" engine are you considering?
I bought this firebird se back in 1998 from the original owner,it has the stock 305 with a Rochester quadrajette 4 barrel. The motor I'm getting is GM #19433033, 5.7 nearly turn key.
Car: One Chevy built in the 80s
Engine: 5.7 crate
Axle/Gears: Quick performance 9” 3.70
I just put the same exact motor in my 84 Z28…your ECM is now just a box with outdated 80s tech in it. I had my trans rebuilt that it will go into overdrive on its own. Question…did you upgrade your fuel tank and pump as well?
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
You can't run a Holley carb while keeping the ECM operational...
Engine: 5.7 crate
As far as am I happy with the motor. You bet, absolutely. Dressed it up a little with different valve covers, air cleaner, etc just because it’s kinda boring looking out the crate. However any reasonably affordable option is better than the bag of 🐕 💩 stuffed under the hoods of the early 3rd gens.
The stock mechanical pump is fine. Yerbasic parts store replacement piece. One worked great on the 400 (big cam, 800 CFM Holley carb, etc.) I had in my car for many years. I WILL add however, that I had a lightweight fuel pump drive rod in it; I had this one https://www.summitracing.com/parts/mor-65750 although there are several others that are similar. I also HIGHLY recommend an insulator such as https://www.summitracing.com/parts/ctr-85-010 (I made one like this out of fiberglass material) to prevent block heat from making the fuel boil off in the carb.
"Dressing up" is for poseurs. No thanks. Krome don't bring the money home.
Engine: 5.7 crate
Did I say chrome? No I did not. In fact I took that ugly crap off mine. But here we are getting WAY off topic. I got a better idea…we put the rulers away and help this guy build a cool car. Isn’t that why we are here in the first place? To share and learn? Who knew…
Now, if his purpose for his car is those "square inches of krome" contests they have in big parking lots on summer Friday evenings, that's one thing. For everything else, "dressing up" is merely a distraction, a shiny thing out in the field off beside the path of truth and usefulness, to be avoided by all who aren't easily distracted by shiny things.
