NEED HELP for my LS swap thanks.
Car: 2018 camaro ss 1le 88 iroc z 95 z28
Engine: Lt4, 305 TPI, LT1
Transmission: Tr6060,IDK, T56
Axle/Gears: ?
I have a 1988 iroc z camaro automatic. About 5 years ago I bought a ls3 and tr6060 out of a 2013 camaro. Was wondering what all I would need to get the most inexpensive but good safe build. I also have a 1995 camaro with a t56 trans and was wondering if that would just slap in? Cause friends said there will be some metal fabrication to get the tr6060 to go in but if there is metal fabrication for both then I will just use the tr6060. In summery was wondering the best yet decent priced wiring harness and brackets and all thanx again
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: NEED HELP for my LS swap thanks.
Welcome aboard. Take a look at the stickies at the top of this forum and read, read, and read again. There are multiple answers to each of your questions and no two swaps are the same. What is your budget and what are your goals?
Few quick things, LT1 T56 is not the same as LS T56. Yes they can be converted but not worth the hassle. TR6060 will require a new tail housing to accommodate a traditional shifter.
Car: 1985 iroc
Engine: 416 ls3
Transmission: t65
Axle/Gears: Ford 9"moser 31 spline 350 gears
Axle/Gears: ?
I have been going thru trying to have someone do it to now it’s gonna be me and my dad taking our time and doing it, so just waiting on my dad to tell me he is ready for me to bring the car and everything over.
I don’t know where the stickies are that someone requested I look at
Car: 1989 Chevy Camaro
Engine: 6.2 376l LS3
Transmission: 4L80E 3k stall
