ls swap differential question
Old Oct 21, 2024 | 05:58 PM
Keaton06's Avatar
Car: 1992 chevrolet camaro rs
Engine: tbi 305 v8
if i were to do lets say, an ls1 swap, would i need to get a newer differential rear end to handle more power, or are they basically all the same?
Old Oct 21, 2024 | 07:13 PM
Re: ls swap differential question
LS1 cars all came with the same model of differential our cars have; the 7½" 10-bolt. Which is NOT to say that "they're the same", or that "they hold up just fine"; only, the exact words I said.
Apart from that, "need to" is a complete other question. How much power are you expecting to apply to it? How much risk of it tearing up and needing to be repaired or replaced are you willing to accept? What's your budget? And so forth.
Old Oct 21, 2024 | 07:22 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
I think the answer depends on how much power the ls will have. How abusive you're gonna be and the condition of the current rear? What's your tire situation?I've seen 150hp lg4s blow up rears when these cars were new. Obviously the drivers were pretty abusive. A built ls will trash a stock rear.
Old Oct 21, 2024 | 08:03 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Majority of LS1 cars get by fine on the 10 bolt axle. Helps to use a structural rear cover.
It costs many thousands of dollars to put in a stronger axle. Can do later if you find out you need it.
Old Oct 21, 2024 | 08:31 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Power alone doesn't break these rears but traction does. Hard launches are a no no with a stock 10bolt. Rolling into the throttle is fine. My 10 bolt is still alive behind my LS but I never launch the car.
rsp13
Jan 22, 2013 06:33 AM
92pukingchick
Dec 3, 2011 06:01 PM
KRACKER JACK
Apr 12, 2009 09:39 PM
third_genbowtie
Southern California Area
Nov 20, 2008 04:07 PM
89IrocPballa
Nov 13, 2007 11:52 AM
