LM7 into a 88 trans am GTA - Need some part advice
Hello!
I'm coming back to this project after a while and I have to admit that I'm a bit lost. I think i've read pretty much every thread on here, but I'm still very unsure on the next steps.
I have a complete LM7+4L60 from a 2000 Suburban with all of the accessories and electronics. So far I've bought a harmonic balancer for a 4th gen F-body which may have been a mistake. I've also bought a UMI performance K-Frame (240131-R). But this kind of where I'm stuck at. I need to buy a new waterpump and I was thinking of buying one for a 4th gen fbody as I saw on a post here somewhere this would give me the most clearance in the front.
My question is this: Can I use the 4th gen balancer and water pump with the rest of the truck accessories? I know for example both Holley and ICT billet offer all sorts of brackets and adapters. I'm happy to return or sell the balancer and go with a complete truck setup if necessary as long as it doesn't cause me any issues.
Car: 1989 Firebird
Engine: 2.8 V6
Re: LM7 into a 88 trans am GTA - Need some part advice
You can't. The LS1 and LM7 used different spacings. Reference this thread:
https://www.thirdgen.org/forums/ltx-...nt-engine.html
There's a couple of options though. You can use the LS3 water pump, which has the correct spacing, and also moves the upper hose to the front to not interfere with a lower intake. If you're worried about space in front of the engine, you'll need to swap everything up front. The Corvette had even tighter spacing.
I should also mention that I've also bought the UMI performance K-frame (UPI-240131-R), so that should give me some extra room for the alternator relocation.
Well, maybe I'll just go with the full f-body setup (after seeing this thread). According to that thread, I'd need to swap out: "Crank pulley, Waterpump, tentioner, powersteering pump, PS Bracket, Alternator bracket, Alternator, Idler pulley & Belt." which I guess isn't too bad. I'll probably just remove the A/C and save some money there.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can make the truck accessories work but it is far easier to put together a 4th gen set-up. I am not sure what your budget is but there are all kinds of aftermarket options as well. However, you should be able to scour the LS1tech's of the world and piece together an OEM system.
) so I think i'll take the easy route.Trending Topics
The truck oil pan won't fit your car either. Or rather, even if it does, it'll hang down so low it might even scrape the ground.
Might want to spend a little time at ls1tech.com and performancetrucks.net. All of this gets talked about rather ALOT in those places; no sense in asking questions one at a time and fumbling around in the dark, when it's all right there already.
I already have a low profile oil pan (and a bunch of other stuff) I just got stuck on the accessory part for whatever reason.
Car: 1984 T/A
Engine: LQ4
Depending on your plans for the build you can use the truck water pump, balancer, power steering and alt. You just need to buy the correct brackets from ict billet or the vender of your choice to rearrange the PS and ALT.
LS3 water pump is the same as truck spacing, Or you can run a water pump spacer with the cheaper fbody pump in truck spacing. This engine has the R4 ac compressor bracket in truck offset
Maybe it doesn't matter at all?
Are either of the pics from your own build?
Car: '90 RS
Engine: 377 LSX
There are many different LS3 water pumps which went on various platforms with different spacing. Camaro, SS, Vette LS3's all had different spacing.
So purchase accordingly.
Car: 1984 T/A
Engine: LQ4
Car: 1984 T/A
Engine: LQ4
Thanks punkmaster98 for your input! I guess costwise this would be the same, as the cheaper pump + spacer kit would be around the same price (or more) as the truck pump. However, the angle of the inlet/outlet neck seems better on the f-body pump. The fbody one sticks out 90 degrees (towards the radiator) while the truck one goes up (towards the hood) and into a 45 ish degree angle.
BrianB
Apr 20, 2003 01:11 AM
