Carbeurated engine in 92 camaro???
Old Feb 7, 2002 | 12:11 AM
strictlypirated's Avatar
How many people have carb'd engines in a later model 3rd gen??? I was reading around, and am really not sure if dropping a carb'd engine into my camaro. your thoughts?
Old Feb 7, 2002 | 09:25 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
I've got a carburetor in my '88 Camaro. I couldn't get the computer calibrated properly for my setup after some fairly extensive modification so I took the easy way out.
Old Feb 7, 2002 | 12:41 PM
CamaroFreak406's Avatar
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
Sure you can put a carb.ed engine in a '92. just take all the wires you don't need and tuck them down the passenger side fender, don't cut any wires at all (In case you ever want to replace the original set-up). I helped a friend put a carb.ed 350 in his '91 no problems at all.
Good Luck
Old Feb 8, 2002 | 04:16 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I've got one in my 91. I will never go back to TPI. Its to expensive.
Old Feb 11, 2002 | 02:49 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
I dropped a carb motor into my 91. I like the power,but I miss the cold weather startup. I just need to fine tune it. Gas mileage sucks,but I guess the cam I put in doesn't help. I just feel I would get a little better mileage from fuel injection. Overall,I like it.The power is definitely there without spending all the big bucks you would need to spend on programming the computer and all the fuel injection related parts.
Old Feb 11, 2002 | 02:15 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Hey RSpeed
Hey. Where did your RS pee?
Hopefully on a Mustang!!!!
"This is Camaro country. On a quite night, you can here a Mustang cry." :sillylol:
AJ
Old Feb 11, 2002 | 05:10 PM
RSpeed's Avatar
Re: Hey RSpeed
AJ
Ha.That's funny.I never saw it like that.It was originally supossed to be RS and speed in one word.
Old Feb 12, 2002 | 07:40 PM
jamesbern's Avatar
Did it to my 92 RS not many problems to speak of. Gas milage with my 383 is right around 20 m.p.g., fuel injection helps but an efficient engine gets good milage so build correctly and tune it right and you won't lose much. If you stick a huge cam in then you probably won't have much gas milage, I used the HotCam. Good luck and don't forget to get an inline electric pump.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
