take off nose to put in new motor?
Old Mar 6, 2002 | 03:07 PM
Sals82Z28's Avatar
Hey guys,
I'm getting ready to put in my new block and was looking at the length of the nose, is it necessary to pull the nose off to put the motor in? Or is the boom long enough? I just got the car painted (then the engine died) so I don't want to scratch it up.
Old Mar 6, 2002 | 06:53 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
It's not necessary at all to take the front bumper off, although you'll want to remove the hood.
Old Mar 6, 2002 | 09:40 PM
mcconahay37's Avatar
Take out the radiator though. Don't want to punch a hole in that. Other than that and te hood, you're good.
Old Mar 6, 2002 | 09:53 PM
Joshua Leslie's Avatar
yeah, I made the same mistake, and ended up fu##in up my front bumper and scrathing it.
You need to take off the hood, and take the motor out from the side of the car, it help to take the tire off the side of the car the hoist is going under.
also, if you do it his way, you dont evenneed to take out the radiator or the belt driven accesories, unless ou have a electric fan, cuz thats bitch to get around!
Old Mar 6, 2002 | 10:02 PM
Guest
Guest
Posts: n/a
Depends on the hoist you get. The short versions will not reach. Putting it in from the side... that doesnt sound like fun.
Old Mar 6, 2002 | 10:36 PM
87RS402's Avatar
Hmm, I used the tow truck to swap mine the last time. I put the wheels in the wheel lift and pulled the engine with the twin line boom. Really that made it too easy, I could move the car front/back-up/down- and tilt, the engine was able to be lifted/lowered-moved front/back and tilted side to side.
Old Mar 7, 2002 | 07:22 AM
Sals82Z28's Avatar
Thanks for the replys. It's a standard size picker - what about putting the pin in the last hole to give the maximum amount of reach? That'll help out alot I think.
I just don't want to scratch up the nose with paint that's only one year old.
The block will be on the lighter side with aluminum heads and intake.
Old Mar 7, 2002 | 11:26 AM
If your's is standard size, it should reach no problem. However, when the engine is being lifted, it will want to move forward and press on the car. Just use some wheel chocks on the engine hoist wheels to keep it from mushing the nose of the car.
Old Mar 9, 2002 | 12:17 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
no need to remove front of car....:lala:
Old Mar 9, 2002 | 11:13 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
You shouldnt have any problems. To be safe though, put a large blanket on the nose to protect the paint.
Old Mar 10, 2002 | 12:51 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
man i wish i were at that stage right now where i was worried about the actually swap
i havent even started building up my motor and its already march
i guess i didnt worry bout the whole swap thing b4 cuz it was pretty easy to do in my bros nova......check it out
Old Mar 11, 2002 | 02:42 AM
EvilCartman's Avatar
Car: '82 Z28
Heh, I should take a pic of the hoist I've got. It's a lift and a press all in one and it uses a hydrolic ram off of a B17. The ram was used on the bomb bay doors. Quick action pump and a hand crank with an up/down lever plus pressure gauge lol... got it at an auction where I picked the car up.
Old Mar 11, 2002 | 01:59 PM
That requires a picture to be posted. You have 1 week to post a pic and make us oooh and aahhh. :hail:
Old Mar 11, 2002 | 10:51 PM
IROC-ZWV's Avatar
that doesnt sound too good....you bought the car...and the hoist to get the engine out at the same auction....package deal i hope?!
Old Mar 12, 2002 | 04:41 AM
Car: '82 Z28
The car was at the auction in the garage with a for sale sign in it.. I picked that up the day after the auction for a new project to work on. The hoist was kind of a necessity at the time just because of the press part of it, buying the car was an afterthought Price was right on the hoist, 50 bucks! I'll try and get a pic up later today.
Old Mar 13, 2002 | 04:22 AM
Car: '82 Z28
Excuse the mess but here's an old picture of it with a dang F*rd motor and tranny at the end of it. That hoist also has a bar that you can steer the front wheels with and one for the rear. Makes things nice hehe you can make it go sideways at about a 45* angle.
Old Mar 14, 2002 | 12:15 PM
primo's Avatar
Can somebody discribe a step by step procedure to unbolt the engine from the car in an 87 350 TPI.
Thanks,
Old Mar 22, 2002 | 07:52 AM
3rdgenvirgin's Avatar
Yee haw, first post on this board, just bought an 86 RS T-Top car for $200....
I will help you guys out, the one tool that you should invest in that every guy should have when pulling a motor is a ..................................................................engine tilter. This is the best tool I have ever owned, lol. You can get them from Summit etc. for about $75 and makes pulling an engine a whole lot easier. Im sure you could tilt the engine down enough to get it past the nose. Have fun and good luck.
Mike:rockon:
jhawkeye
May 25, 2022 06:33 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
86White_T/A305
Aug 17, 2015 12:16 AM
slade5612
Aug 11, 2015 07:19 PM
Leggman1
Aug 6, 2015 04:15 AM
