help with vortec heads
Old Mar 13, 2002 | 04:34 AM
simple's Avatar
what would be needed to have my existing TPI/vortech setup work with a pair of vortec heads?
so far, not much mods have been done. just the blower, gutted cats, flowmaster, and a shift kit. for now, im looking for the best set of heads for my current setup for under 1k. helpe me!
Old Mar 13, 2002 | 11:00 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You're going to cut it close for $1k. The Vortec base is $400, heads $450, installation parts & gaskets for the base another $100, you'll want better valve springs than the Vortecs have, then there's always the "incidentals". Don't forget shipping.
Or, instead of spending the money on the base, get alternative heads like Worlds or Corvette heads that your current base will bolt to.
Old Mar 13, 2002 | 08:11 PM
simple's Avatar
will the TPI bolt directly to world sportsman or torquer heads without any problems?
Old Mar 13, 2002 | 10:55 PM
five7kid's Avatar
I don't believe the Sportsmans are available with the '87-later intake bolt pattern (but I may be wrong about that). That's a simple mod to the center two bolt holes on each side of the intake, though. The Torquers are available in '87-later style, so they should just bolt on.
Old Mar 13, 2002 | 11:02 PM
simple's Avatar
cool, thanks alot for all your help
Old Mar 14, 2002 | 04:46 AM
simple's Avatar
what cam would you recommend using, given my current mods including a pair of torquer heads? i see alot of people agreeing that the zz4 cam works well with a blower running low boost and a relatively mild 350. any ideas?
Old Mar 14, 2002 | 06:30 PM
five7kid's Avatar
The power adder guys would probably be a better source of info for that.
Old Mar 14, 2002 | 09:41 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The Sportsman II's are available with 87&up intake face, their part# 012260-1, w/1.25" single springs
part# 012260-2, w/1.437" dual springs (better choice)
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
