Gas struts for the bonnet ??
Car: Camaro IROC
Engine: 305ci
Hi,
Mines have completely gave up the ghost !
So where is the best place for new ones ?
Or is there any alternative ??
Another vehicle that has the same type fitted ?
Cheers,
Alan........
Cheers,
Alan........
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Total: $44.45 USD
Including UK delivery, from "The Parts Store" on E-bay.
Just bought some, got fed up of bumps on the head.
http://stores.ebay.com/The-Parts-Store
Car: Camaro IROC
Engine: 305ci
Cheers mate,
Went to a show last week and hid my broom handle in the boot, just held the bonnet up and tried to look casual!!
Alan..........
Alan..........
Car: 92 z28
Engine: 5.7
Transmission: auto
dont bother buying new ones,as I did ,they only last 3 years before the start sagging again.Could buy a fiber glass bonnet ,and then you can use your old ones.
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Originally Posted by R1UK
Total: $44.45 USD
eBay Store - Hood Trunk Hatch Struts Shocks Lift Supports: Hood Shocks Struts Lifts Prop, Trunk Supports Gas Props
For that sort of money, I dont think you can go wrong, think I paid around that? Haven't sorted out the rears yet though. Have u ever tried to balance the rear glass on your head while putting away the t-tops
Car: 1987 Camaro Z28
Engine: 5.0 TPI
http://search.ebay.co.uk/_W0QQfgtpZ1...Z57chevygirl57
I got some boot struts from this seller a few weeks back. Brilliant customer service and the price is pretty good if you ask me.
Specify the gas springs for a Trans Am - They have a bit more pressure for the slightly heavier load. Do the same for the rear. There used to be three different pressures. The highest were for the '86-87 Trans Am / GTA due to the urethane rear spoiler.
Fronts are 95051/E95051, rears are 92003 (Pro-Lift 0374952003).
Mine have lasted since April of 1996. Once I get it off the pull-down, the rear hatch will still just about knock me in the chin if I don't pay attenation.
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Broom handle every time! You did well getting 3 years out of them. If you have headers I've seen them go within a year
Car: 91 Z28
Transmission: Slushbox/ NeeddT56 transplant!
You guys should try replacing the pop up spring as well, you know when you have to pull on the hood to get it to unlatch! $8 off of ebay, the hood, or bonnet pops up alot better, more space to get your hand under there!
