Smog pump Help!
Old May 25, 2002 | 11:36 PM
quiksilver1j's Avatar
Smog pump Help!
Today i removed all of my smog pump stuff but i don't know what the plug the stock headers with until i get aftermarket ones. I tried to go NAPA to find a bolt to put it there and by following their chats its a 14mm 1.5 thread but they don't have it !!! so i went every where and cant find anything with those deminsions what should i do. i don't really wanna break those air railings cause i might need them in the future. any responce would be appciated!!
Old May 26, 2002 | 12:18 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
you dont need to plug them you can leave the stock AIR fittings in there
Old May 26, 2002 | 07:08 PM
I had to get those stupid tubes out of there they take up too much room
Old May 26, 2002 | 07:13 PM
3/8"
Old Jun 13, 2002 | 02:14 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
1/8" NPT pipe plugs, need 8 of them.
Old Jun 13, 2002 | 05:59 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
i used jbweld
Old Jun 13, 2002 | 06:23 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
You can just leave them in there and cap the main tubes with a 5/8" (i think) pipe cap. I did this to mine, but it's just temporary until I get the headers on.
Old Jun 13, 2002 | 07:00 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
If you follow the lines up, they all come together before they go into a check valve. Take it off there. You will need a 1" wrench and a adj wrench. Unscrew it and put on a brass fitting. Once it fills up with pressure it will not cause any turblance. I did it to mine.
Old Jun 20, 2002 | 08:08 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
I just did this on a buick..I took the tubes out of the manifolds...trimmed them to the fittings and then welded them shut. Screwed the fittings back in like little plugs
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
