Cant Get Muffler Off, Help
Old May 27, 2002 | 01:23 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Hey guys, I just put a flowmaster muffler on a few months ago, but the drivers side pipe always hits the side of the well in the trunk. So now what I have to do is take the old muffler off so that I can fit a little extension pipe in between the I-pipe and the muffler inlet. I bought a little dohickey that restores the little dent in the muffler from the clamp, but thats AFTER I get the darned muffler off. How do I get it off without having to call Meineke? Get two cars, tie the muffler to the left, tie the I-Pipe to the right and have them floor it in reverse? I'm debating that one. Any ideas? Thanks.
Old May 27, 2002 | 05:36 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
sawzall, hacksaw, cutter
Old May 27, 2002 | 05:43 PM
Marshall89ws6's Avatar
get a grinder...... it works realllll good
Old May 27, 2002 | 10:42 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
they make hand held pipe cutting tools, shouldn't be too much, and its a clean cut
Old May 27, 2002 | 11:35 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You could try heating the muffler with a torch and using a big lever to pry it off, i hope it works.
Old May 28, 2002 | 02:21 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Use something to hole the I-Pipe in place, ie. floor jack or put some blocks inbetween the rearend and the I-Pipe, just to hold it still. Then take a rubber mallot and try to beat the muffler off. (Man that didnt sound good) A little lube and some heat wouldnt hurt. (Goodness, that either).
Old May 28, 2002 | 02:16 PM
All right you guys, thanks. I'm gonna try not to cut anything, cuz the pipe is short as is.
Old May 28, 2002 | 09:58 PM
polishdevil's Avatar
Car: 88 GTA
Try a flat head screwdriver and a hammer, that's how i did both of mine.
Old May 29, 2002 | 02:20 PM
yeah i can't get at it with a screwdriver from that angle
Old May 29, 2002 | 04:46 PM
89Irocz23's Avatar
I dunno if u have this tool but, but when I had the stock exuast on and I had to change my fuel pump I used a AIR chistel. It came off pretty easy, but people dont have one of those.
Old May 29, 2002 | 06:31 PM
DSaylor's Avatar
Another idea, when i changed mufflers , mine was crimped pretty bad so I cut two slits lengthwise along the pipe *180 across from each other, and kind of bent the two halves out from the other pipe.
Kind of hard to explain but it should work
FormulasOnly
Jul 23, 2018 08:47 AM
cstrobel65
Sep 16, 2015 11:54 AM
