Hooker Super Comp Question
Old Jun 13, 2002 | 07:29 PM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
I just recieved a set of Hooker Super Comp Headers (P/N: 2210). To my surprise, the passenger side header is in 2 pieces - the rearward headpipe is not welded on, it slips into another tube. I assume that this is for ease of installation (so it doesn't get hung up on the starter). I've never run into this situation before. The instructions simply say to "install R-4 headpipe in sliptube on main body of header" - nothing about welding or other means of fastening the two tubes together. Surely this setup will result in an exhaust leak, won't it? Anyone with these headers, how did you fasten the tubes?
Old Jun 15, 2002 | 06:36 PM
LILRED383's Avatar
Dude, I got the same headers about a year ago, and my passenger side header was not in two pieces. I mean, the flange that connects to the head was in two pieces, but all my tbes were connected. I bought mine directly from Jet Hot, so I'm not sure if they received from that way from hooker, but that doesn't sound right. Have you contacted Hooker about this?:nono:
Old Jun 15, 2002 | 06:43 PM
tommyboy's Avatar
Car: 87 Formula
Engine: 355
Transmission: TH400
Axle/Gears: 5.00
That is the way they are. Slip them together and run them.
Old Jun 15, 2002 | 10:22 PM
Fast3rdGen's Avatar
mine was 2 pieces too......just install it and leave it....no leaks here
Old Jun 17, 2002 | 05:04 PM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
Thanks for the replies guys. I think that I'll use a small exhaust clamp just to be sure (if I can find one to fit 1 3/4" DIA).
Old Jun 17, 2002 | 08:31 PM
Fast3rdGen's Avatar
NOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!! don't use any clamps!!!!!!!! then you'll risk warping the tube and then you WILL have a leak. leave it alone trust me.........on hooker's s10 long tubes the driver side header has 2 or 3 slip fit primary tubes to wrap around the frame and they don't use any clamps and they don't leak.
Old Jun 17, 2002 | 09:04 PM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
OK, I won't clamp it!
They're going on the SB Chevy 400 that I'm dropping in my '91 Firebird this coming Saturday. If it does leak, I can always clamp or weld it at a later time (and I'll come on here and make fun of you ). But you sound confident, so I'm hoping you're right.
Thanks again
Old Jun 18, 2002 | 04:01 PM
Fast3rdGen's Avatar
Re: OK, I won't clamp it!
Thanks again
fair enough lol
Old Jun 19, 2002 | 01:06 AM
1TUF92Z's Avatar
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
Super Comps
I have the same headers in my 92Z with a 406 and 3 other friends in their 3rd gen also. Just slip it on and there should be no leaks. Well, at least mine does not leak. So don't make fun of me if yours does. ha ha ha ha
Old Jun 17, 2007 | 07:53 PM
Heymoe29's Avatar
Car: 03 Suburban,87 Iroc
Engine: 5.7 TPI
Transmission: AUTO 700R4
Axle/Gears: ?
Re: Super Comps
I have these on my 87 Iroc and have no leaks. However I am in need of a little assistance. I Blew the passenger side gasket and I am having a hell of a time getting them back together. Is there a better tool to use to get the bolts good and tight. I am new to this and could use a little guidance from the Vets. Any help would be great.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
redmaroz
Aug 16, 2015 11:40 PM
makaveli09
Aug 12, 2015 09:07 PM
