having troubles removing exhaust manifolds, can you help me?
Old Jul 25, 2002 | 06:29 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I have all the bolts off of the passenger side except the farthest one back and the one that the dipstick is attached to. Number one, how do you get the dipstick out of the way to extract the bolt. I thought it was a press fit into the block. i tried to pull it out and it wouldnt budge. Secondly, are there any hints on removing the last bolt on the passenger side. I have tried stubby wrenches, regular wrenches, from up top, from undernieth, gallons of WD40. Any tips. I can get the stubby wrench on it but I do not have any leverage to get it started.
Old Jul 26, 2002 | 07:58 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
If you drop your exhaust you can get the rear most one from under the car with a regular combo wrench or come to think of it I think I used a short socket and ratchet. The one with the dipstick is a stud with the dipstick attached by a nut, remove the nut, pull the dipstick out and remove the stud.
Old Jul 26, 2002 | 08:27 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I have the whole y-pipe assembly out of the car but I can't seem to get a wrench on the nut. As for the dipstick I removed it from that stud and I geus I will start yankin on it.
Old Jul 26, 2002 | 11:01 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
now just pull the dipstick straight out
Old Jul 26, 2002 | 04:06 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Well I pulled and pulled and pulled and the dipstick didn't budge. So I beat the **** out of it and kinked it in like 5 spots and now it is uterly useless, but hey it is still in.
Old Jul 26, 2002 | 07:52 PM
RICHRAD's Avatar
The other day I was looking at my exhaust manifold bolts while looking to see what else I'll need to remove to get my headers in. I noticed on some of the bolts there appeared to be a metal tab bent over some of the hex points. O.k. looks easy to bend upright and get the socket on there. Felt of that back pass. side and yes that tab was there but couldn't figure how I was going to get the tab straightened out on that one. Well, maybe you have a tab problem and it's just hard to tell in a poorly lit area.
Old Jul 28, 2002 | 12:50 AM
TheLG4Whore's Avatar
Car: '86 Trans Am
Transmission: TH700R-4
Axle/Gears: 10 bolt 3.73
Oxy cut 'em!
Old Jul 28, 2002 | 09:03 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I eventually got that bolt out. The dipstick never made it out and now it is a mangled mess. I was able to bend the tab up from undernieth with a 90* screwdriver. I had to have someone guide me. I was only able to budge it a litte but than I used the spare tire jack to pry it up the rest of the way. That thing came in so much use believe it or not. I finally yanked on the manifold while spraying WD40 on the head and bolt and it got it loose. I then just slowy unscreded it. Huge Pain though. I just hope I don't have any leaks and that the car runs.
transaero
Aug 31, 2015 01:14 AM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
